I backed my files up but now i cant retrieve them back why is that..its not showing up on my computer just a whole bunch of folders and i don't know how to look for my specific folder because i had help backing them up but that guy is unreachable and now i am stuck trying to get or even look at whats on the drive .i need help..i need answers pleassee....
If you can remember any of the back up file names click start type in
backup or any part of the name of the backup files made press ENTER this should take you to the back up folder location you might have try a few times to get it right
depending on your computer and operating system this can vary
hope it helps
SOURCE: Not able copy folders from able to copy folders across from Passport drive onto PC desktop
hmm..is the drive visible in the my computer panel? and you could do a global search and copy and paste if that goes quicker..
SOURCE: WD Passport Essential 160gb with PowerBook G4
The problem is that your powerbook G4 does not provide enough power to your 160gb passport HD. This does not happens to the new Macs with intel inside.
There are several ways to fix it:
1) Go to West Digital Website and buy a "Power Buster Cable USB" (that connect your 2 USB ports to your passport HD in order to provide more power). I think that it costs 10$. This is the link: http://www.wdc.com/en/products/accessories.asp?ProdID=170
2) The other solution is easier. If you have an external USB hard drive with two USB ports, or a DVD/CD burner with two usb ports, you can pug your passport in one of the ports while the other HD or DVD/CD burner is connected to you PowerBook. You will be able to see and use your q60gb Passport HD.
SOURCE: can't access files on external hard drive
Hi All had the same prob with my external drive and used a program called Easy recovery professional it worked for me .hope this works
SOURCE: I just cannot fiew my files I backed up. I do not see the ALacie in the device drivers
if ur drive is in NTFS format plz go to the drive right click on that drive go to properties go to security and tick on allow ,before tick allow u should untick all the deny coulmn
SOURCE: doesn't show any files and folders when drive opened
Congrats, You got a nice virus. Its better you backup your drivers and data from ur root partition format it. reinstall your operating system and install avg 8.5 before browsing any of the other partition. I can surely tell u your task manager, registry editor or show hide folder won't be working. There is no permanent solution to this other than format. But beware don't browse other partition before installing avg 8.5. Your earlier installed antivir has given its way to virus its of no use. You won't be able to install antivirus or visit any malware removal virus site. welcome back.
