Question about Mitsubishi WS-65908 TV
Ws-65908 tv heats up and shuts down, i have uncovered front and stays running as soon as i close it after a few minutes it will shut down
    Sergeant:
  • 337 Answers
The fact that removing the front helps does not really means anything but is good that you have notice,the age of the set has a lot to do with the problem,I am sure it has many loose conections that need to be resoldered regarless,all sets have many components that disipate a lot of heat and over the years the solder cracks and it forms a ring ,this makes the set intermiatnt until no conection exist any more and it stops working for good.What does the unit do when it shutsdown? does it show a picture with lines that is red ,green or blue and then it shutsdown? or it just goes off? if it shows you a color like I mention it could be the picture tube of that color and the repair will be expensive but it could also be a loose conection somewhere in the power supply or the deflection panel,If you are familiar with repairs ot TV's you can possible take care of it but if you are not familiar with electronics call a qualified technician.I hope you can use this information.
Posted on Nov 30, 2008
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Power on for 3 seconds then shuts off
Do the self test this model has:
When set shuts off and on front of set power light goes out:
Press and hold on the front of the set both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks a pause and then repeats it several times.
This feature will narrow down where the problem is.
Let me know what error code is found and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 29, 2010 | Mitsubishi WS-65908 TV
Mitsubishi WS-65908 Error Code 24
If you have an ohm meter, check the resistance from F9A04 to ground, and then reverse the leads and check F9A05 to ground. These supply +24 and -24 to the convergence integrated circuits. The conv ic's may be bad. Also, code 24 usually indicates vertical deflection failure as well. One other check to make.....The pic tubes on this set may leak a few drops of coolant onto the boards. Look VERY carefully for liquid drops on the boards or a green and or white corrosion spot or two on the boards under the pic tubes-near the front of the chassis.
Dec 12, 2008 | Mitsubishi WS-65908 TV
Tv shuts off but when i open the covers to let air in it stays on
commen prob solid state equip. heat sen comp prob horiz circuit need tech or insall small fan .
Nov 30, 2008 | Mitsubishi WS-65908 TV
TV shuts itself off
Mine does the same thing , too. I turn it on and off repeatedly , but nothing happens.I unplug it to see if it resets and nothing still .
Aug 02, 2008 | Mitsubishi WS-65908 TV
JENN-AIR Oven shuts off and comes back on after several minutes
they are equiped with a heat sensor it could be a bad thermastat(sensor) or
ventalation problem
Nov 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Mitsubishi WS-65908 TV Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
