My front loading washing machine stops in the middle of the washing
  • 33 Answers
Usually there is an error code associated with abnormal operation. If there is any problem, the unit will shut down. For instance if the clothes are off balance it will shut down. If the pump can't pump the water out during spin, then it will shut down. There is a sequence of steps used to isolate the problem. One must have the proper codes to access the troubleshooting mode. The most common problem is that the pump is being blocked by lint,etc in the clean out basket located beneath the front of the machine. If it is jampacked with lint,etc. then remove all visible and then restart the machine.
Posted on Nov 30, 2008
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
Stops in middle of cycle and won't drain or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer stopped in the middle of a load. It agitated & washed, but didn't not drain.
heatman101
Sep 27, 2010 | Whirlpool Washing Machines
At the middle of my load there was stop with code symbol E3
E3 is that the machine can't see that the motor is spinning. Could either be a loose connector at the motor or a loose hall-effect sensor. this might be a fairly easy fix for a repair tech,
Dec 27, 2009 | Maytag MAH8700A Front Load Washer
In the middle of a cycle, it has stopped and is
nf is NO fill
i would check your cold water line
take it off the machine and check the screen as well
no fill means it is timming out waiting for water
Oct 09, 2009 | Samsung WF337AA Front Load Washer
Washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Dec 15, 2008 | Whirlpool GHW9100L Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
WasherFrigidaire Front Load Washer
"dr" is a door problem. Most likely not closed properly or a problem with the latch mechanism.
Aug 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
