When installing gas firelogs, where does the long copper line probe go?
  • 61 Answers
The probe measures temperature in the room so it can cut the unit on and off automatically, always refer back to you user manual. If you have more questions please post back
Posted on Nov 30, 2008
How do i eliminate moisture from an underground,natural gas galvanized gas line. I have no gas flow to my garage or my 75k garage heater.
Check on the local codes governing gas piping, but it would be my suggestion to consider abandoning the existing line IF you are sure there is a compromise to its integrity allowing water to enter. I would think if water ENTERS...then GAS has to be able to excape. It'd be a lot of condensation that's required to either just block the line or freeze and block the line. If it freezes due to lack of depth, it's going to rupture anyway sooner or later necessitating replacement.
At the above ground location before where it goes subterranean, (after checking the codes), consider installing the appropriate brass fittings to then allow a new underground copper line to be installed by attaching by means of an iron pipe to flare adapter in the appropriate size. Then utilize type L soft roll copper to lay in the new trench to the garage and tie it into the existing line inside the wall. Type L is the thick walled soft tubing and can be used in many locations for gas, whereas Type M soft copper tubing is thin walled tubing for use with water and not gases. Your area may not allow it. That's what building inspectors are for.
Before proceeding, MAKE SURE your line is in fact the problem then double check with a local authority whether or not copper materials are recommended along with brass fittings for the connections. IF the original and suspected problematic gas line is for sure GALVANIZED it is not in any way approved for use with natural gas. It is probably black iron pipe.
Jan 03, 2015 | Heating & Cooling
The polit will not stay on even after holding down the on/off control for 2 to 3 minutes.
Sounds like you have a bad Pilot Safety also known as a Thermocouple. If you look at the pilot, you will notice a small copper probe that is in the flame of the pilot. Follow the probe back to the gas valve and remove it. No gas will leak out. Bring the whole probe to a good hardware store or fireplace shop for a new one.
Mar 06, 2011 | Universal Remote Control Heating & Cooling
I have a 25000 btu Empire and I can not get the pilot light to stay lit. Any thoughts
The pilot safety is bad. It is also called a thermocouple. If you look at the pilot through the viewing port you will see a copper probe that will work its way to the gas valve. This is the thermocouple. To remove it, remove the 10 or so screws holding the burner box to the bottom of the combustion chamber, remove the screw holding the pilot assembly to the burner and slowly wiggle out the entire pilot assembly. Unscrew the copper probe from the gas valve than turn it out of the pilot assembly Take it to a good hardware store and match up the length. You may have to purchase a longer one but you can coil up any extra. Reverse the removal procedure to install and make sure you seal up the burner box with high temp silicon prior to lighting.
Jan 23, 2011 | Heating & Cooling
I need to install a new therm a coupler on my stove but can't find my manuel lost it in a fire. Any help appreciated
This is a fairly simple fix. On the pilot end see the probe, it mounts in a bracket that holds the probe in the pilot. From the probe runs a copper line that goes into the gas valve. Just detach from both ends remove and replace. If you have the exact part its just a swap out. If you have bought a generic (one size fits all kit) this may require putting some bends in the copper line. Place the probe in the bracket in the pilot use gentle bends to get the gas valve end to line up to where it attaches to gas valve. Be careful not to kink the copper line,this will ruin it.
Oct 14, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Pilot light keeps going out,,,thermal couple?
Yep! Find the gas valve and trace the copper line going in to the pilot area. You will need to remove the logs as well as a dab of silicon where the line goes into the pilot assembly. Once you get to the probe end of the thermocouple, there is a friction clip holding it in the holder. You can attempt to unscrew it or you could give it a quick yank down. Take it with you when you get another one. If you need to, you can get a longer one and tuck the extra inside. Silicon the hole back shut after installation.
Jan 23, 2010 | Leisure HOMEPRIDE Electric Fireplace...
I just installed a 50,000 Btu williams hearth heater with the fake firelogs. The unit fires when the t-stat is turned up, but the blower doesn't blow and unit was kind of smoking near the exhaust upon...
before you kill someone get a qualified technician to your house . when ever your dealing with a fuel burning appliance that emits CO and gas its critical that its installed properly or you may experience property damage or worse death
Oct 18, 2009 | Heating & Cooling
Pilot light comes on but oven wont heat up
The gas valve has a bimetal flap in it that is acticated by the small probe washing in the flame of that pilot light. Clever ain't it? Sometimes you can re position that probe to where more flame hits the tip of the copper/nickel probe. The 2 metals trun into a battery when heated up and millivolts are produced. The probe simply wears out over time. The whole valve needs to be replaced. You cannot just replace the probe. The new part will not be preset. make sure the orifice is at the same height as the old one before install. Bubble test and you should be good. This is not hard and not scary. But be sure to bubble test for gas leaks. Take a look at these repair pix
Aug 20, 2009 | Kitchen Ranges
Install gas fire logs
That goes IN to or close to the actual Fire Bed ... it is your Thermo-probe that reports back to the unit that it is "On"
Nov 30, 2008 | Heating & Cooling
Gas firelog pilot light will not stay lite
try to replace the thermo couple
Nov 25, 2008 | Heating & Cooling
AM-50BAE won't stop making ice
There should be a copper bulb located in the ice bin. This is the probe for the thermostat. If you follow the copper line connected to this bulb it will bring you to the thermostat, and you may can adjust it. Please let me know if you need any more help.
Nov 23, 2008 | Hoshizaki AM-50BAE Drain Pump Kit
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
