Question about Linksys Wireless-G WPS54G Print Server
Linksys Wireless-G Print Server
After I install the Macfee Wireless Security software. I can no longer print. I can reach the internet but I only see the usb light on the print server. I tried the reset button but nothing is working.
    New Friend:
  • 12 Answers
Dear Davisj, This is a typical problem that occurs when you have an active firewall. Try disabling the firewall and you should be able to print. Linksys is known for their customer service and expertise, I would suggest giving these folks a call at: 1-800-LINKSYS, they will walk you through the process of setting this up correctly. If you don't want to call, the problem lies in your firewall. Look for the IP address on the printed test page. If you are using a Linksys router with a default IP address of 192.168.1.1, the printserver should be getting an IP range of 192.168.1.x as well indicating that it is properly obtaining an IP address from the network. Once you locate your IP address all you need to do is go to your Firewall settings for your Mcafee software and add permission to add a specific IP address and you will enter your Print Server's IP address. This should fix your problem! Good luck! The following link should provide you with additional details to fix your Print Server: http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859942287&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=4228741076B05
Posted on Apr 08, 2007
My linksys WPS54G print server no longer works since I bought a new router, a linksys WRT54G2 router.
your using same information ssid and wep
chanell 11
b+g mix
my email to follow up
i work for linksys and verizon internet
Dec 23, 2009 | Linksys Wireless-G WPS54G Print Server
Connecting this print server
try unplugging both and then plug in the router,let it reboot, then plug in the other and let them find each other. if that doesn't work let me know.
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Tip
Installation CD for the print server
If you are having trouble going through the setup process on the installation cd do the following:
  1. Disable any encryption settings on your wireless router.
  2. Disable MAC filtering.
If these features are enabled during the installation setup process, the wireless features will not work unless you go into the admin settings of the print server by typing the IP address into internet explorer. Type in the correct encryption settings.
Linksys has a provision in the setup software to key in the correct encryption however the software doesn't put the information in properly. This will cause the wireless not to work and allow the print server to work only when it is wired to the network.
Encryption settings have to be entered through the administration settings of the router by typing in the IP address of the print server using internet explorer.
on Jul 20, 2008 | Linksys WPSM54G Print Server
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
I have a netgear wireless network. I am trying to
you can use sharing printer.. even your are using wireless can print as long as you are connected on that network and secondly the same name of workgroup.
Sep 09, 2009 | Linksys Wireless-G WPS54G Print Server
Linksys Wireless G Print Server set up
Hardwire the wps54g to the router and disable all firewall installed on the compute.
Sep 07, 2009 | Linksys Wireless-G WPS54G Print Server
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
Wireless print server
If your WEP encryption key is turned on, it will not work. To correct this, go into Internet Explorer and type in the IP address of the printer. Type in the WEP key in the correct place and save the information to the print server, then restart the search program.
There is a detailed thread I posted on this last July on Fixa. You should be able to find it by searching under the Linksys print server by the model number.
Nov 17, 2008 | Lexmark P4350 All-In-One InkJet Printer
Linksys Wireless-G WPS54G Print Server Logo
634 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
