Question about Panasonic DMR-E50 DVD Recorder
My panasonic wireless surround sound won't work out of the Rear speakers
I have purchased a panasonic sc-ht545w home cinema system with wireless rear speakers. The front left, right, centre & sub speakers all work. However the rear speakers do not work. I have checked that the wireless reciever is connected & plugged in correctly & that the speaker wires are connected to the back of the wireless reciever. I have also checked that the "W" is permanently on the dvd/amp meaning that the wireless is receiving a signal. Yet still no sound.
  • 4 more comments
  • mikehar Dec 20, 2007
    i have the same problem, everything wired in according to instruction manual i can hear power to rear speakers but no sound. Please help.
  • Neil123 Jan 04, 2008
    I have the same problem, the only sound I can hear is a continuous buzzing sound, does anyone know how I can at least fix the buzzing ?
  • baad Apr 03, 2008
    I have the same problem but my W is continuously flashing
  • Anonymous May 08, 2008
    anyone no how to fix this problem
  • Anonymous May 09, 2008
    i get like a buzzing noise from my rear speakers
  • harry64 Sep 21, 2008
    I have exactly the same problem
    is there something else you have to do to get them on?
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Posted on Jan 04, 2008
SOURCE:
Hi I've got a Panasonic sc bt100 home cinema could someone tell me how to get the surrounds to work without having wireless speakers I've noticed inputs on the back of the system but it doesn't work ?
Not quite understanding what your problem. The surrounds simply connect to the rear connections of the amp. The rears will only play when the source material has surround info.
Sep 02, 2016 | Panasonic Audio Players & Recorders
Home Cinema Wireless Kit
It may be favorable to simply purchase a rear wireless speaker system all by itself and use the existing system for surround sound applications. Monoprice . Com has some units are a good price.
Mar 05, 2014 | Panasonic Audio Players & Recorders
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
http://service.us.panasonic.com/OPERMANPDF/SCBT100.PDF
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
Panasonic Wireless Rear Speakers Ticking
move ur speakers around. if the noise is absent on some places u can be sure its the digital box. or one fix that might work is - get aluminium foils and wrap ur speakers. this can blank out interferences. if that works, open ur speakers and line the walls with thick aluminium foils. hope this helps.
Apr 13, 2010 | Panasonic Home Theater System System
Rear speakers not working
Some TV is not broadcast in surround... you will not get back speakers from TV, only from DVD.
Feb 16, 2009 | Panasonic Home Theater System System
Panasonic SC-660 speaker problems
The center and rear speakers are off if the PLII is disabled, make sure it is enabled by pressing the PLII button in the remote, you should see it on the display
Jan 22, 2009 | Panasonic SC-PT660 Theater System
Wireless speakers won't connect
You try upgrade the main set to 5.1 or 7.1 channel is it?
If the wireless is green light mean the main set is recognize the wireless.
You need to setup the speaker output from main set by "Setup" button on remote control.
Can refer Operating instruction manual in main set.
Nov 29, 2008 | Panasonic Home Theater System System
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Fornt speakers does not have any sound.
remove the front speakers cables from the rear-remove surround speaker cables from the rear and put them in the place of front speaker-run a music if you get good sound the problem in your front speakers(speaker or its cable)-if you got nothing you will have a problem in your system itself and need to fix in service center.
Aug 29, 2007 | Panasonic SC-HT930 System
Poor Surround Sound
There is a setting in the dvd player to up the rear speakers to a + setting you have to dig deeep somewhere in the speaker settings. mine did the same thing till I found it.
Jan 08, 2007 | Panasonic SC-HT940 System
Panasonic DMR-E50 DVD Recorder Logo
2,275 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
