Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
F-1 alarm beeping
F-1 alarm keeps going off. What does this mean?
  • arnelsearch Dec 01, 2008
    can you not just fix the youch pad? since it works for 20 mins after you reset the breaker.
  • 78 Answers
Tuch pad needs to be replace
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Nov 30, 2008
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
My oven keeps randomly beeping and flashing F-1 recently. When I push cancel it stops, sometimes for an hour and sometimes for a week. I have tried to reset by turing circuit on and off, but problem does...
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
May 11, 2011 | Maytag Ovens
The oven keeps blinking F2 what does that mean
F2 Heating mode high temperature This alarm is activated when the ERC senses a runaway heat condition or when the temperature exceeds "runaway limits". The ERC will beep until the cancel or another function is selected. If the alarm repeats the F2 code check the oven sensor and wiring after first checking for a stuck relay. If alarm goes away verify the oven will complete a clean cycle without any type of failure.
Nov 25, 2010 | Dacor Ovens
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
F-1 showing
It is a pretty common annoyance for many, some are able to disconnect the power and it seems to go away, but if it continues f-1 means EOC (Electronic Oven Control) Failure so if it persists it needs to be replaced. Maybe you had a powersurge recently or it could be just worn out
Sears is a department store. They do not build their own appliances. They contract with many different manufacturers to build all of their appliances.
Sep 24, 2008 | Kenmore 41389 Electric Double Oven
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
75 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
