Question about Sony KP-53S65 53" Rear Projection Television
Need to know part number or value for C514 in horiz out put circuit for kp-53s65
Set made popping noise picture shrunk dowm to circle. this cap had blown.
    President:
  • 1,284 Answers
C514 has three different values possible. Just use this value as it has worked fine for me in the past. 680pf /2kv Sony part# 1-162-116-00
Posted on Jan 21, 2007
SOURCE:
Burnt out EY34
EY34 is a location near a small blue capacitor that commonly burns up; Location number for the cap should be C514 and the values of it are 1,000 pf (pico farad) at 2 KV (2,000 volt rated).
Often if it is burnt it is the only problem and both Hitachi and Sony used the same identical part in several of their sets.
Let me know if you have questions.
sd tech
Sep 25, 2011 | Sony KP-53S65 53" Rear Projection...
I HAVE A SONY KP-53S65 PROJECTION TV AND I HAVE NO PICTURE OR SOUND. THE POWER STAND-BY LIGHT BLINKS BUT NOTHING ELSE COMES ON. I HAVE READ THE MANUAL WITH NO RESULTS. COULD IT BE THE LAMP? IF SO WHERE DO...
A lot of times when that problem happens, its most likely not the lamp, when the lamp is the issue you can still hear a sound on your TV but no picture, most likely where looking at a problem with your power supply board or ballast, there might be something wrong with them that keeps from sending voltage to the lamp and audio parts, but on the other hand if you wish to change your lamp, depending on the model it can be on the back or sides of the TV, there is a little door with 4 screws that leads to the housing where the lamp is, you just need to pull out the housing and take it apart, its a actually a very easy task, you can have it done in like 5 min. an easier way is to purchase the whole lamp with the housing and just pull the old one and insert the new one in, less than 5 min!! If you have any other question don't hesitate on asking.
Mar 16, 2010 | Sony KP-53S65 53" Rear Projection...
When I turn on my sony (KP 53S65) the screen doesn't light up
The most common problem for this TV is a bad capacitor (C514)
Call a good TV Tech and have him check for that first. Should be a $125 job at the most
Jul 31, 2009 | Sony KP-53HS30 53" Rear Projection...
Trying to identify a capacitor on the power supply board
IF you have the G BOARD part #A-1316-367-A it's:
1-162-133-00 CERAMIC 390PF 10% 2KV
IF you have the G BOARD part #A-1316-422-A it's:
1-161-754-00 CERAMIC 0.001MF 10% 2KV
Jan 04, 2009 | Sony KP-53S65 53" Rear Projection...
Sony kp-53s65 rear projection
C514 is a ceramic capacitor its ratings are 390PF 2KV @10% tolerance
Jun 07, 2008 | Sony KP-53S65 53" Rear Projection...
Sony KP 53S65 Rear Projection TV
I don't know if this will help you but I just experienced a similiar problem with a sony kp-53s35.
It turns out that a fluid leaked out of a rubber boot on one of the guns( I have no idea what the fluid is or why it is corrosive), down to a circuit board and started to desolve a jumper wire. when it had eaten away enough of the wire, the residue or solution1.gif was conductive enough to cause an arc to a ground bus bar that ran along the circuit board. The TV still worked but would crack and pop like firecrackers inside.
I was able to increase the distance to the ground source by bending the bar away. Then I scraped and scrubbed the board with contact cleaner to remove residue and replaced jumper wire.
Has worked fine since.
Mar 18, 2007 | Sony KP-53S65 53" Rear Projection...
Standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Dec 11, 2006 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
141 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
