Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier 394jaw036045 furnace won't light
I can hear the clicking, igniter but no spark.  A diagnostic manual is needed as to identify what part is needed.  The igniter is a 3 wire.
  • 10,515 Answers
  • 4 more comments
  • taran_2005
    taran_2005 Nov 30, 2008
    If u wana download manual, direct link wld be :-
    http://mfc.engr.arizona.edu/documents/LP...
    Thnx.
  • taran_2005
    Hey,
    a spl gift for u :p
    DIAGNOSTIC MODEULE FOR GAS FURNACE AND WAYS TO RESOLVE IT WITHOUT ANY HELP
    http://homerepair.about.com/od/heatingco...
    Thnx.
  • jeffeverde Nov 29, 2010
    Manual is totally unrelated to a Carrier / Payne 394jaw036045
    suggested troubleshooting consists of- "Is it plugged in? Is it turned on? Call a technician"
    sorry -- that's LH680005
    clicking ignitor but no pilot could be the pilot assembly or the main gas valve (assuming, of course, that you've first verified that the gas is turned ON (blue knob on the control valve, and shut-off valve on the gas line somewhere outside the furnace cabinet)).
    Your pilot assembly is an LH680005, and can be found online for $65-120
    Your gas valve is a Carrier EF32CB197 (actually, a White-Rodgers 36e93-301-- new part# 36e93-304). The valve can be found online for $85 to $200
    Genius:
  • 3,422 Answers
Please click HERE for Manual.
Let me know if you need anything.
Good luck
Posted on Nov 30, 2008
    manual referenced has nothing in common with a Carrier / Payne 394jaw036045
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Tip
Carrier Weathermaker 9200 Gas Furnace Error Code 31
A month or so ago, I woke up to discover that I had no heat in my house. I went to the furnace to do a diagnostic check, removed the service door and quickly discovered that there was no flame (visible through the glass peep-hole).
I followed the manufacturer's shut-off procedure, which can be found in the manual, here: http://legalectric.org/f/2011/03/carrier-9200-weathermaker-uhe-om58-67.pdf. When I turned the furnace back on, I saw that the igniter did not glow (should be visible through the same peep-hole - should look like a red-hot, 2-prong tuning fork) and that the red LED error code indicator (visible through the lower peep-hole) was blinking 3 short flashes and 1 long flash (error code 31).
Now what I SHOULD HAVE done was check the pressure switch first (see service manual pg. 3, component #16). By removing the rubber lines that connect tot the pressure switch, one end at a time and both at the pressure switch and the bottom of the igniter box, you may notice some debris in the lines or the male adapters on the pressure switch or igniter box. If you do, clear out the debris with a paper clip (don't insert the paper clip into the body of the pressure switch, though). After checking all connections for debris, disconnect the hose that connects to the top of the pressure switch at the "T" between the pressure switch and the igniter box and blow/suck air in and out of the pressure switch (lightly). If you hear a small click when you pass air in and out, that's the pressure switch functioning. If you hear crackling or you can't blow in/out easily, you probably have a bad pressure switch.
if you are able to make the pressure switch click, connect all lines and start up the furnace per the mfg recommendations. If the furnace kicks on, it was probably a blockage in the pressure switch lines (likely if you found gunk in the lines or male adaptors on the pressure switch), but it may still be a faulty pressure switch (my problem... when I blew in and out to the pressure switch, I could hear the silicone diaphragm cracking). I got mine going, albeit temporarily, by removing the pressure switch and passing air in and out (blowing pretty hard) with my lips on the bottom hose adapter until I could hear the diaphragm crackle free and it became easier to make it click on and off. That only bought me a few days, though. After that, I bought a replacement pressure switch at a plumbing supply place and replaced the old one. If you found gunk in the lines, I would suggest you have your furnace serviced and let the tech know what you found and where.
If neither procedure fixes the problem, it may be the igniter. For some odd reason, this issue started for me about a month ago and I replaced the igniter (YouTube video instructions are easy to find), which fixed the problem. If even that doesn't work, call a local tech, shut the gas off and wait around in some thick blankets! I hope this helped!
on Jan 08, 2015 | Heating & Cooling
I have an Atwood 8531 furnace and the blower comes gas is flowing but it won't light and it says ignition lockout fault
Can you hear ignitor sparking when gas flowing? How did you confirm gas is flowing?
May 05, 2013 | Heating & Cooling
I have an electronic ignition furnace that won't spark. The blower turns on after about 30 seconds from hearing the ignition clicking but no spark. I noticed when I completed the lighting proced
On that unit the induced draft motor must close the pressure switch, and all safeties are proven closed, then that signal is powered to the ignition control board. Then the board sends a spark. Lots of times all that happens and the electrode that makes the spark needs cleaning, or the ground for that electrode needs to be cleaned/tightened. Takes some process of elimination for that one.
Oct 29, 2017 | Heating & Cooling
How to install a spark ignitor in a gas furnace?
How to install a spark ignitor in a gas furnace? - Fixya
www.fixya.com/support/t15727344-install_spark_ignitor_in_gas_furnace
Jan 8, 2013 - How do I connect the high voltage wire to the Model 990-516 spark - Air ... SOURCE: Goodman furnace wont light, ignitor suspected. Notice.
carrier igniter
Jan 08, 2013 | Heating & Cooling
Furnace won't turn on
What is the make and model# of your Furnace? And is it a pilot light, or a hot surface Igniter?
Dec 29, 2012 | Heating & Cooling
York furnace won't ignite
Is the igniter receiving 120 volts after the pressure switch closes? If not, either the board is bad or the pressure switch is open
Nov 27, 2012 | Heating & Cooling
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
VulcN MODEL gc04C CONVECTION OVEN WON;T IGNITE ER-05 CODE
Like an electronic igniter for a gas grill? I believe you can pick up a replacement. Call Lowes or Homedepot. I know i have saw individual igniter's before my friends bought some for my friend and I when we were little to make potato cannons.
Jan 22, 2008 | Vulcan GCO2D Gas Single Oven
Ignition failure
THE AUTOMATIC IGNITION IS TIMMING OUT BECAUSE IT WILL NOT LIGHT PROBABLY A BAD THERMOCOUPLER TRY TO LIGHT IT MANUALY
Jan 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
659 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
