22" oscillating pedestal 3 speed model 10203 motor not working. almost seized.
SOURCE: I need to reverse rotation
Below is a wiring diagram for a multi-speed single-phase electric motor, being 1 the slowest and 4 the fastest.
You can reverse the motor rotation by rewiring the motor as shown below.
SOURCE: wiring
12,000-BTU Portable Air Conditioner with Manual ... 3135 30-Inch Oscillating Industrial-Grade Pedestal Fan ~ Lasko ... 42.62 : Soleus Air FCM-30 12-Inch Convertible Stand/Table Fan ...
SOURCE: Broken ceiling fan switch
NOT ALL SWITCHES ARE THE SAME!!!! Some are single layer and some are not!!. I think you can tell by the body color of the switch. Red and Black, Grey and Black, ETC. I figured this out after buying 3 of the wrong switches. Each one hooks up a little different. If it is an aloha brand fan like sold at WalMart it is a common issue. Just call there 800 number and they will send you a new one. You have to know the exact model number of have the bar code. Usually there is a bar code on top of the motor. Just take it down from the ceiling and look. I called them on Thursday and got a free switch and capacitor on Monday!! My fan is going great again. If you have the old switch check it or just call the fan's customer service!!
Just call 1-800-295-4448. Even the call is free.
SOURCE: I have the aloha model 5745, need to replace speed
when I turn my fan on, it will not come on, I can come back in the room in a few minutes and it will be on, whats my problem
SOURCE: Aloha Breeze 16" Vintage Stand Fan Model #46051
It isn't worth fixing. I am on my second one which didn't last any longer than the first which was about 3-4 months. These fan motors are junk. First failure was a bearing and when it started failing, it was noisy. Eventually, the fan would not start because the motor didn't have enough torque to overcome the friction in the bad bearing.
The second fan was quiet but has NO starting torque....no unusual for fans generally, but I'll NEVER BUY another ALOHA BREEZE product again.
