Question about Tappan TGF320 Gas Kitchen Range
Stove's pilot lights are lit but wont ignite the burner
  • Nette 23 Dec 19, 2008
    Tappan Model # MPF303PGDG
  • prygrocki Jan 28, 2009
    stove's pilot lights are lit but won't ignite the burner anywhere from 5 to 40 minutes
  • 338 Answers
You could have a bad flame switch. what is your model number?
Posted on Nov 30, 2008
The pilot light will only stay lit when you hold the pilot reset button in, as soon as you let the button out the pilot light goes out and the actual burners never come on. Any ideas?
Gas line is clogged if your pilot lite goes out - They got rid of pilot stoves because the pilot was always lit and using gas.
And without a lit pilot no way you can get the burner to ignite unless you use a match, assuming you have gas going to the burner!
Nov 08, 2015 | Heating & Cooling
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Right, front flat burner does not light and barely heats. My Hotpoint stove is five years old and gets very little use. What's wrong? Can I fix it? Can you help?
Hello and Welcome to FixYa!
Please provide us with the model details of your unit and What exactly, you are facing. Is the burner properly getting the supply. And is it partially lighting or didn't lighting at all. Is the unit repaired ever since the problem started? Some details of the trouble, you are facing, will help suggesting more precise solutions to the problem,
Feel free to Ask,
Jul 15, 2011 | Hotpoint Kitchen Ranges
My whirlpool gas range is getting gas and is clean but will not ignite.
Not knowing whether you have an electric ignition or pilot I will make suggestions for both.
Electric -
There is a thermal sensor that detects if it hot or lit. So if this sensor is bad or shorted it will not try to ignite, however if it is every burner / oven device, then its probably the computer that controls the igniter.
Pilot -
Typicaly the piloted gas stoves will not supply gas to the burners / oven if that pilot is not burning, however there is a sensor similar to the on on the electric ignition that lets the stove know if the pilot is lit. Unfortunately this sensor is not electric in almost all cases and is not easy to replace.
If you have the parts list, this sensor will be called a thermocouple usually in both types, but can be called other things. I would go with this and if all else fails replace the whole ignition system (electric) or pilot valve (piloted).
Jun 24, 2010 | Kitchen Ranges
O'Keefe & Merritt Contempo Gas Stove Oven won't light
Probably needs the ignitor replaced.
May 24, 2010 | Kitchen Ranges
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
Pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
Mar 24, 2009 | Kitchen Ranges
Pilot and burners
You need to check a couple of things, first is the flame sensor, second is the thermostat. Without anymore detailed info this is the most I can give you.
Nov 08, 2007 | Uniflame 200209 Open Flame Patio Heater
Tappan TGF320 Gas Kitchen Range Logo
75 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
