Question about Panasonic PT-51HX41 51" Rear Projection Television
Sound but no picture!
Replaced the convergence amps and now after hooking up the tv i have no picture. the 3 tubes on the bottom of the tv are lit, but on top i have no picture or channel indicator and no set up lights on the screen. can you give me some tips on how to get this lit up?
thanks
denny
  • Panasonic Master
  • 8,617 Answers
Try unplugging the three convergence yoke plugs and then try powering up the set. If the set lights up the tubes, you will need to troubleshoot the convergence circuits as something is still wrong possibly the feed resistors are blown.
Posted on Nov 30, 2008
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have pink and green wavy lines. Most pronounced at the bottom of the screen.
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Just the blue on my rca projection tv is blurred. on the auto convergeance it says it cant read the sensor. on manual the cross hairs for the blue are oversized and blurred. i tryed tuning in the focus but...
Have you try adjusting your focus/screen drive controls to Tube R/G/B you have a focus/screen drive control block to adjust each Tube 3 controls ontop 3under them top ones are for Focus bottom is for screen drive.Red/Green/Blue Tubes.You might need to replace convergence IC, what is your Model number printed on back of TV?
Mar 24, 2010 | Televison & Video
I have a philips projection tv, there is a green hald circle at the bottom of the screen also the picture has double images and very yellow and red. I just bought this from someone who keeps telling me its...
It sounds like multiple problems. First of all these sets are famous for bad coolant between the tubes and lenses causing the picture to be degraded causing the foggy picture. The fluid can be changed to clear up the halo's. The double images are convergence issues. Most likely both convergence amps need to be replaced. I hate to say it but it sounds like you got a money pit. Good luck. Thanks for using fixya.
Dec 21, 2009 | Philips Televison & Video
Philips Projection picture
You have bad convergence amps, tubes are fine unless you had a hazy looking picture before the convergence went out.To fix the haze the fluid in the picture tubes would have to be changed out.
Dec 10, 2008 | Philips 60PP9202 60" Rear Projection...
I would double check the wire connections especially the bridged connectors that connect the A and D boards also see if the wire from the front panel PCB is actually hooked up. Often its easy to get a wire plug mixed up and plugged into the wrong socket or not seated properly.
Nov 30, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Convergence
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
TV won't come on!
Most likely, this is a problem with the convergence board. The convergence amps (STK392-040 x 2)are internally shorted. These can be replaced or the whole convergence board can be replaced. It's cheaper to replace the amps, but more convienent to replace the board (especially for the less electronically inclined!! :) Also, this could be from a leaking CRT. In CRT projection televisions, the red, green, and blue tube are filled with coolent (glycol). These 42" models are very bad about the tubes leaking (Akai and Samsung models)and are infamous for destroying the CRT driver board connected to the bottom of each tube. When this happens, the protection circuit kicks in and will not let the television start up. *PLEASE, FOR YOUR OWN SAKE, DO NOT FOLLOW THESE NEXT STEPS IF YOU HAVE NO UNDERSTANDING OF ELECTRONIC EQUIPMENT!!!! There are four screws and three snap clips that hold the bottom on. UNPLUG THE TELEVISION, remove the screws and pull bottom outward to remove. The bottoms of the three tubes should be visible. DON'T TOUCH THEM!! Now look under each tube. If one is leaking, there will be a wet spot (or sometimes a puddle!) underneath the tube. This will have to be serviced by a TV tech. Hope this helps...
Jan 26, 2007 | Akai PT4799HD Rear Projection Television
Convergence and picture problems
This TV probably uses two convergence IC Packs that will need to be replaced and be re-converged. There may also be a resistor or two that may need replacing as well. The projection tubes should last another 3 years or so.
Dec 26, 2006 | Apex Digital GB43HD09 43" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
