Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
F1 alarm beeping
Kenmore oven, single , gas- has started w/ F-1 beeping. Now won't stop , what to do?
  • 78 Answers
Replace tuch pad
Posted on Nov 30, 2008
My oven has been beeping for the last couple of hours. My son pushed bake and put the temp up to 425. After it preheated, it started beeping and F1 is showing on the display. I have tried everything to...
you can first try to reset the curcuit breaker
flip on and off
if this does not help
usually an f1 error is your control board
what is your full model number from inside the oven?
Apr 22, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Error message on Kenmore oven
F-1 is not good. It basically means the EOC (electronic oven control is bad). There is a little test here for a little info:
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire won't stop beeping f1 style
HI, this is a electronic oven control board failure code.
Replace this damaged electronic oven control (also called EOC or clock). It has failed.
Aug 13, 2009 | Frigidaire FEB27S5A Electric Single Oven
Error f1 and beeping sound when the oven is on. Heating non stop.
Your digital panel may still be under warranty. It may be worth your while to have a tech look at it. Something else is going on here.
Jan 12, 2009 | Kenmore 47783 Electric Single Oven
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F1 display and alarm will not shut off
hi there,
can you tell me the model # on your stove please?
Sep 13, 2008 | Maytag CWG3100A Gas Single Oven
Kenmore electric oven 337098
While I can't promise results, it sounds similar to a problem I have helped over 1100 other solve. Please go to the following link: http://fp1.centurytel.net/Powerman/Dreaded F7 Problem.pdf Let me know if it works for you. You can email me at hutchipop@yahoo.com
Aug 20, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Aug 22, 2006 | Magic Chef 9512 Electric Single Oven
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
217 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
