Question about Sony CFD-G50 Cassette/CD Boombox
I NEED A ANTENNA FOR BOOMBOX MODEL CFD-G50 /SONY
BROKEN ANTENNA
jackboy
  • 2985 Answers
SOURCE: sony cfd-8 boombox randomly skips
Gently dust if out with a soft brush Then get a CD Lens cleaner disk and run it. Should do the job.
Posted on May 19, 2007
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Posted on Jun 12, 2008
  • 4234 Answers
SOURCE: broken antenna
The Sony part number is: 175422611 and the part is available for $15.95 from tritronicsinc.com or any other Sony parts distributor.
Dan
Posted on Oct 08, 2008
  • 561 Answers
SOURCE: how do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Posted on Jan 01, 2010
SOURCE: CFD-S300 Sony Boombox lost power cord
What should be the secondary voltage be on 115 volt primary transformer off the power cord for the CFD-S300
Posted on Aug 23, 2010
Tacoma(1997) power antenna mast with broken cord will not come out after the chrome nut is removed. Any suggestions? Antenna motor still works.
Power Antenna Mast Replacement 97 fjz-80 ' IH8MUD Forum
forum.ih8mud.com > Forums > Toyota Tech Forums > 80-Series Tech
Oct 1, 2010 - I'm looking for a "how to" on replacing the OEM power mast on a 97 LC. ... The only tricky part is removing the funky nut that holds the mast in. .... what to do with the radio mast on my newly acquired 1997 Lexus LX450. ... if I have a broken cable, but the antenna itself comes right out of the top with no cable.
How to rebuild the power antenna - Cadillac Forums
www.cadillacforums.com > ... > Cadillac Tech Tips - How to fix it
May 9, 2009 - 15 posts - ‎12 authors
Remove the liner to access the antenna and disconnect ANY of the two ... If notlocked the motor receives continuously power and will drain ... Broken nylon wire lifting/lowering the antenna mast 4. ... The motor shaft comes out from the plastic casing after you take out ... Do not lubricate the cable or the mast.
Saabnet.comt Broken Antenna FAQ - The Saab Network
www.saabnet.com/tsn/faq/antenna.html
If the cable broke in the antenna, you need to remove the antenna to remove the ... take a 17 mm wrench and remove the nut over the antenna where the mast comes out of the body. ... Hopefully the chrome sleeve will come with the old mast. ... Be careful not to drop them down too far. get the motor assembly on a bench ...Missing: tacoma ‎1997
How To Repair A Broken Car Antenna -EricTheCarGuy ...
? 20:53
https://www.youtube.com/watch?v=zcKwFto9_s0
May 24, 2013 - Uploaded by EricTheCarGuy
This video shows one way you can deal with a broken antenna. ... Find out why ... this video is that I did ...Missing: chrome
Jan 12, 2016 | 1997 Toyota Tacoma
Is a replacement antenna an easy fix for ordinary person (Sony cfd-10 boombox)?
All antennas are the easiest repair an non-electronics technician can try to do
Oct 07, 2013 | Sony CFD G505 Boombox
Antenna relay switch
is it original antenna and radio? the antenna runs on a seperate switch oor goes up and down with radio on and off switch? if it is original stereo that is original chances are the antenna is broken and stuck in up position the mast may be purchased at dealership but motor may also be no good or not far behind. Listen at antenna for motor noise when radio is turned off if you hear the motor the plasic that drives it inside is broken.
Apr 02, 2013 | 2000 Cadillac Eldorado
Where can i fine antenna replacement for sony xplod cfd-g505
Go on line to the SONY website and request the parts list for your boombox. THen order it!
Jan 01, 2013 | Sony CFD G505 Boombox
Need a relacement anntena for sony cfd-s22
Radio Shack is the only store that carries a variety of antenna's, but not sure if they still do.
Apr 12, 2012 | Sony Boom Box With CD Player & Cassette...
Where can i find an antenna base for the sony cfd-s300 model
One way to find replacement is to purchase one that cab be used for parts only.
See the link below, on ebay there is one the is for sell under $10. It does not work and you can remove parts to repair yours.
http://www.ebay.com/itm/Sony-CD-Stereo-Player-CFD-S300-Portable-/160674611448?pt=LH_DefaultDomain_0&hash=item2568f400f8
Nov 18, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
I am looking for a power cord for a sony zs-s2ip boombox. where can i get a replacement or is it generic?
Not knowing what country you're in...
Does it LOOK generic? Then it is. Take it down to an electrical supply store or Radio Shack or look around online. "generic power cord"
Aug 24, 2011 | Sony CFD-G50 Cassette/CD Boombox
Need a replacement antenna for CFD-S22 model
Radio Shack carries a varieties of antenna's, or tv repair shop.
Feb 16, 2011 | Sony CFD-S22 Cassette/CD Boombox
Antenna broken off inside base
There should be a ring with a couple of notches in it at the base of where the antenna use to be. This ring is essentially a nut and is threaded and can be easily removed giving you better access to the broken antenna. I'm assuming that you are referring to a power antenna also.
Jan 26, 2011 | Ford Focus Cars & Trucks
Sony CFD-G50 Cassette/CD Boombox Logo
154 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
