Question about Saeco Magic De Luxe Espresso Machine
No power to saeco magic expresso machine - Saeco Magic De Luxe Espresso Machine
  • 3 more comments
  • mjbindy Dec 01, 2008
    My Saeco Magic expresso maker is not getting any power, o lights noise etc. It is not the outlet or power cord. The brew group is jammed and can not be removed.
    Where do I find the service manual or how can I unjam the Magic expresso maker
    Ihave a users manual. Where is the service manual.
    I removed the tray and the dump box and was able to remove the brew group. The brew group, box and tray. Reseated all three. Still no power, no noise, no lights.
    Natrin
    How can I descale if it won't turn on.
    Genius:
  • 1,011 Answers
Sir,
check this link
1. Unplug the machine.
2. Remove the top plate.
3. Notice that there are three thermostats, two on the top and one onthe side of the boiler. Locate the thermostat on the side of theboiler; notice that there is a red button on the top of thisthermostat. Press this button. You may not hear a click, or any othersort of indication that anything has happened.
>See the picture here: http://www.jlhufford.com/images/ranciliotherm.gif for a look at the thermostat in question.
4. Replace the top plate.
5. Plug in the machine and fire it up.
The machine needs to be reset when the boiler overheats. The boileroverheats usually only if there is a power surge or if the water runsout of the reservoir. To prevent the heating element from burning out,the thermostat kills power to the element. Keep your eyes peeled forany whitish residue in the water that comes out of the group head. This is an indication that the heating element may have been damaged,and the boiler may need to be replaced.
PLEASE, PLEASE, PLEASE don't run your machine out of water! This,along with sediment and coffee oil build up are the primary reasons weget many machines in for repair.
check out for instruction manual at http://products.saeco.com/index.asp?id_paese=7
thanks
good luck
Posted on Dec 01, 2008
    Sergeant:
  • 237 Answers
How long have you had this machine? Before taking it to the repair shop, make sure it is not the wall outlet's lack of power. Plug it into a different outlet.
    Sergeant:
  • 217 Answers
U will require a manual to disassemble the machine and this is the link for the manual just click it.http://kitchen.manualsonline.com/manuals/mfg/saeco_coffee_makers/saeco_magic_comfort_type_sup_012de_espresso_machine.html
  • 73 Answers
First have you made sure the socket is working and checked the fuse in the plug, the next part would be to make sure there is no break in the cable, then you would have to take it apart and check that you have power there however you should not do this if you have not worked with electrics before as it can be very dangerous
    Sergeant:
  • 306 Answers
U will hav to to descale your machine to try out further...
  • 734 Answers
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
    Master:
  • 505 Answers
Ok, so you can download a new user manual for your saeco coffee machine here http://www.coffeeshrine.com.au/user-manuals/
let me know if you have any specific question following this.
Thanks
  • 6,487 Answers
YOu need to dismantle this unit to fix the jammed parts inside it if you have the servcie mnaul for this you can find the steps on how to dismantle it but if its still under warranty better take it to a servcie center to fix it for free.....
    Genius:
  • 2,035 Answers
Try to plug the different Ac mains and check if it powers on ,or check if the fuse is blown the in the machine...
Good luck...
  • Anand Kumar
    Anand Kumar Dec 01, 2008
    Close the door and switch on the machine. The brew unit will move back into position.and then remove it ....
  • 13,433 Answers
You said the machine is not getting power? is the cable cut? if the cable is fine then:
  1. Check the fuse
  2. Check the power switch
After checking these two it may be a other component failure or maybe the cable is cut at some point. After checking these two I would suggest you take it to a professional or continue testing if you feel confidend about doing it , you might want to buy a service manual to help you, but Im not sure if one is available for this, I will see if I can find one.
  • Ekse Dec 01, 2008
    Have you checked the fuse and the power switch on the coffee machine??
How do i turn off the descaling light
Hello info 11220,
I understand you need to turn of the descaling light on you Saeco Magic De Luxe Expresso Machine. The only thing you need to do after you get done descaling the unit is to hold down the steam button for 5 seconds and the light should go out. If you have any more questions please feel free to ask.
Thank you for choosing FixYa.com
Justin
Mar 09, 2011 | Saeco Magic De Luxe Espresso Machine
Seaco magic delux expresso machine
They do not post a manual per se, but they have a step-by-step set up guide, starting on this page:
http://www.saecosupport.com/PartsMDSR.html
The actual user manual (less useful for first time) is here:
http://216.244.99.185/custompages/Manuals/Magic%20Deluxe.pdf
-Tha Mp3 Doctor
Mar 23, 2009 | Saeco Vienna De Luxe Espresso Machine
Tip is broken - Saeco Magic Deluxe Expresso, Coffee Maker
In the UK Saeco parts are supplied by Gaggia UK in Halifax
Dec 13, 2008 | Saeco Magic De Luxe Espresso Machine
Looking for user's manual for Saeco Stratos Expresso Machine
There are a user manual on this site under Saeco/magic de luxe espresso machine.
Aug 09, 2008 | Saeco Magic De Luxe Espresso Machine
Grinder does not work
I have the spare part number to the grinder.
0301.R01.00A 230V
0301.R001.00F 100V
Hope this will help you.
Jul 20, 2008 | Saeco Magic De Luxe Espresso Machine
My expresso wanted a fix.
go to www.saecooutlet.com and there should be a link for service centers.
Don't know about the other states, but stay clear of the ones in Illinois. I've heard people having nightmares with the 2 there.
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
Need a User Manual
their site can give you the manual
Apr 23, 2008 | Saeco Magic De Luxe Espresso Machine
Missing the metal coffee holders for an expresso machine
What kind of machine do you have, can you find the model no.
Apr 17, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco expresso machine
www.saeco.ca
1743 Boundary Road
Vancouver, BC
(604) 299-7555
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
