Question about Kenmore 24032\24036 Top Load Washer
I just need to replace the water valve.
My main problem is figuring out how to take the back off. I have a kenmore 20702990. I have taken all visible screws off but nothing seems to want to budge and i dont want to break anything.
  • 33 Answers
Improper model #. Sometimes letter"O" looks like zero or a "D"
There are so many different machines that I'd need the proper model # to help any more.
Posted on Nov 30, 2008
How do I figure out why my Kenmore 500 series washer wont fill with water-just hums.
check if water supply is on dont take for accont that it is i have seen it all frozen and closed I assure you then check that filter in hoses and water valve isnt filled with debris is all is good change the water inlet valves
Feb 21, 2015 | Kenmore Washing Machines
2002 kenmore 51262103
Unfortunately the valve that is in the back of the frig needs to be replaced. For some reason this valve that the main hose goes in goes bad and the water dispenser won't work. I had the same problem on my Frigidaire and had to replace the valve in the back.
Aug 17, 2014 | Refrigerators
Kenmore 17379 dishes are not clean after running a cycle
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Jan 31, 2011 | Kenmore 24 in. 17372 / 17374 / 17379...
Inlet valve continues to let water in when door is opened and when the float is up
The needle in the water valve is not seating all the way closed. Some thing has gotten under the seat sand or limed build up. The valve will have to be taken apart and cleaned or replaced. In either case you will have to shut the main water supply to the dishwasher to stop it from letting water in.
Jan 21, 2011 | Kenmore Dishwashers
After spin clothes are still wet kenmore 110-20702990
If your clothes are still wet after a spin cycle it can indicate that you may have either a drainage issue and the water is coming back into the machine after the spin, or your drain pump has broken some or all of its impellers that force the water out. i hope you found this useful.
Thanks.
Oct 10, 2009 | Kenmore Washing Machines
Waher won't spin
Either a bad lid switch or a bad direct drive coupling or a bad timer.
Fill the machine with water. In the wash mode observe the agitator. Is it moving back and forth? If no, replace the direct drive coupling.
If yes, it does move back and forth, with the lid closed, advance the timer to the spin cycle. If it does not spin, raise the lid then close the lid. Does it spin? If yes, replace the timer.If no, replace the lid switch..
Apr 08, 2009 | Kenmore Washing Machines
Kenmore HE3 washer
The water valve is not closing fully. You will need to replace the water valve.
Mar 31, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
New filter but water dispenser still not working
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Mar 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore washer leaks water,
on the back of the machine there a two water inlet valves, these are electric solenoid valves and one of them is leaking.  You need to remove the back panel on the washer to replace this valve assembly.  It's a common easily obtained part.
Dec 30, 2008 | Kenmore 24902 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
