Question about Cooler Master Computers & Internet
I lost a couple of the plastic Hard Drive slides
The hard drive has plastic slides with metal pins. Lost them. Can I get a set somewhere??
  • 49 Answers
Is it possible to just use scews? If not find cooler master tech supportand try to find out if you can find replacement parts.
II had a zalman gpu cooler that I lost a couple of springs and scews to ad I was able to call tech support and they sent me to a websie to buy replacement oem parts since it wasnt under warrany. This may help I am not sure.
Posted on Nov 30, 2008
How do I remove the hard drive from the enclosure? If it's supposed to slide out easily, it isn't...
It is standard for 4 screws to be holding the hard drive in. Maybe there is a plastic tab somewhere holding it in
May 17, 2015 | ConnectLand USB 2.0 External Enclosure for...
Toshiba disk drive mk6028gal
The hard disk drive (HDD) in your Toshiba laptop is the component that holds all the files and folders you use.
If you are running out of room on the hard disk drive because of all the programs you have installed, it may be time to replace it with a new one that has a larger capacity.
Replacing the hard disk drive on a Toshiba laptop is a fairly straightforward and simple process, as you only need to remove one other component to be able to reach the hard drive.
Save a backup copy of any file or program that you will need from the original hard disk drive to an external device such as a CD-RW or USB flash drive.
Shut down the Toshiba laptop's operating system completely.
Disconnect the power cable if it was plugged in and then close the top screen lid.
Flip the entire unit over so that the bottom end of the laptop case is facing towards you.
Hold down the release latch for the Toshiba laptop's battery.
Slide the laptop battery out of the case and then put it aside.
Locate the screw at the upper-left corner of the case that holds the CD or DVD drive into place.
Remove the screw and set it aside. Grab the edge of the CD or DVD drive and then pull it away from the Toshiba laptop case. Set the drive aside.
Remove the four screws holding the large square plastic cover over the hard disk drive at the lower left end of the laptop case.
Lift the square plastic cover off the laptop case and set it aside so that you can see the metal plate that covers the hard disk drive.
Take out the screws holding the metal plate in place.
Lift the metal plate out of the case and set it aside.
Remove the two screws at the top edge of the hard disk drive and then the two screws at the bottom edge of the hard disk drive.
Disconnect the hard drive from the motherboard by sliding it out towards you.
Lift the hard disk drive out of the case and set it aside.
Push the new hard drive into the open slot and then reconnect the four screws.
Set the metal plate back on top of the new hard disk drive and then attach its screws.
Put the plastic cover on and reattach the cover's screws.
Slide the CD or DVD drive back into its port and then reconnect the screw.
Put the battery back into the Toshiba laptop.
Turn the laptop over and open up the screen.
Power the computer on. Insert the recovery disk that came with the Toshiba laptop into the CD or DVD drive.
Follow the operating system installation instructions that will appear on the screen.
Transfer the backup copies of the files you saved earlier from the external device to the new hard drive.
Toshiba Satellite hard drive replacement
Aug 13, 2013 | Computers & Internet
Can I get a new mother board for my HP Pavilion Slimline s5120f computer, so I can reinstall my old hard drive with out losing my software.
Yes you can install a hard drive on any computer as long as it has the same power and data connections and plugs.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards If your current hard drive is on the fritz, or you have an older drive with data you need to retrieve, it's a fairly short process to swap out an existing drive with an old unit lying around the house. To replace the hard drive you need to be comfortable taking apart your computer and working inside its case. The hard drive is located in the series of metal drive bays located underneath the computer's side access panel.
Shut down your computer's operating system. Disconnect the power cable from the back of the computer case and unplug any other cables, such as for the monitor and mouse. Set the computer case gently on its side on a stable work area such as a desk or table. Check the far left end of the case to determine if the side access panel uses screws or a release button. Remove the two screws with a Phillips screwdriver, if they are present. Instead press in the plastic release button, if one is present. Push down the side panel and slide it off the computer. With some models you may need to instead lift the panel to the right until it locks at 90 degrees. Check the metal drive bays near the front end of the case and locate the one containing the rectangular metal hard drive. Unplug the data cable and the power cable from the ports on the back end of the hard drive. Remove the screws holding the hard drive to the metal drive bay. Set the screws aside in a container so they don't become lost. Grip the back of the current hard drive and slide it out of the drive bay. Slide the old hard drive you want to use into the drive bay, and ensure the power and data cable ports are facing into the computer's case. Plug the power and data cables you removed earlier into the corresponding ports on the back end of the old hard drive. Replace the screws removed earlier to hold the old hard drive to the metal drive bay. Replace the computer's side access panel and tighten the screws in place, if it used them. Reconnect the computer's power cable and the other cables you removed earlier. Press the computer's power button. Hope this helps.
Dec 26, 2012 | Computers & Internet
Hard drive failure messege
You will need to replace the hard drive and restore the operating system.
The hard drive is located on the bottom of the laptop. Look for the small ~2.5" x ~3.5" cover generally held on by two Philips screws. Take the cover off and there my be a couple more screws remove if needed and slide the drive out. There my be a small plastic tab or strap you can use to slide the drive out.
You can get cheap replacement drives from bestbuy for $45 dollars or from any online retailer such as etc. If the drive has a bunch of pins on it then it is IDE 2.5" drive if its newer and has black plastic L spaced connectors then you want a 2.5" sata drive.
Once the drive is replaced you will need the system recovery disc set for your computer. These can be ordered from the manufacturer of your laptop for $15-90 depending on the manufacturer.
Insert the disc and follow the prompts to restore your computer.
Comment back for further assistance if needed.
Aug 26, 2011 | Computers & Internet
I dont know how to set jumpers to work as a slave
Just look for the little plastic squares that slide onto two pins. They will be where you you plug the cable and power into the hard drive.
There should be a diagram on the label. If not, you can look at the bottom of the hard drive - right by the pins, and you should see SL, CS..... in small text on the green board. This is for SLave, Cable Select........
Go to the maxtor website for more details.
Feb 27, 2010 | Maxtor Hard Drive
How do you set this drive to be the slave drive
There are a few pins on the back with slide on jumpers. USUALLY the drive will have a label on it showing where the jumpers go for master or slave mode.
Use a pair of tweezers to move the jumpers as they are usually hard to pull out with bare fingers. They are usually a little plastic box with a metal clip inside.
Jan 27, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
How do you take a ignition switch out of a 1977 chevy pickup with a non tilt steering column?
Pop the center out of the wheel, disconnect the horn. Remove the big nut. Use steering wheel puller to remove wheel.
DC horn wiring again, remove plastic cover. Depress lock plate and remove circlip. DO NOT LOOSE. remove lock plate. some have a small 3/16 allen screw holding key tumbler in others have a flat spring to depress.
If the actual switch (not lock cyl) is bad you will have to lower the colum from the dash Remove screws (4) holding te plastic piece under the colum2 bolts it will swing down and allow access to the ignition Sw, top side of the colum.
Sep 19, 2009 | 1977 Chevrolet Silverado 2500
Reinstall Hard Drive
  1. Step 1 Back up your data. Make sure you back up any important data stored on the hard drive in the event something goes wrong. Also, if you are selling or giving the hard drive to someone else, you should erase any data on the disk by formatting it.
  2. Step 2 Open the case. Remove any metal rings, watches or bracelets you may be wearing. Unplug the computer from the electrical outlet, then touch the metal casing to eliminate any static charge. You can also use an anti-static wrist strap if you prefer. Check the user's manual if necessary to determine how to open your particular PC case.
  3. Step 3 Locate the hard drive. Typically the hard drive will be connected to a flat 2 1/2 inch wide IDE cable and a power cable. Hard drives are often housed in removable metal cages which are secured to the computer case with one or more screws. Refer to your user's manual to locate the hard drive if necessary.
  4. Step 4 Disconnect the hard drive. Unplug the hard drive from the IDE and power cables. Grab the plastic IDE cable connector with your thumb and forefinger and gently pull until the connector breaks free. The power cable can be difficult to remove if the connector is fitted tightly. Make sure you don't bend any of the pins when disconnecting the cables.
  5. Step 5 Remove the hard drive. If the hard drive is fitted in a metal cage, locate and remove the screws that are holding the cage in place. Hold your hand under the cage to catch it if necessary. Once the cage is free, remove the small screws on either side of the hard drive to remove it from the cage. If the hard drive is connected directly to the computer case, simply remove the screws on each side of the hard drive and slide it out of the case.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
How do i change jumper leads on cd/dvd drive
There are no actual "jumper leads" on a CD/DVD drive although there is a jumper to set the drive as either Master,Slavve or Cable Select.
This is a small plastic covered metal "clip" located at the back of the drive ans covers 2 of the 6 pins.
The settings are usually stamped in the casing of the drive above each set of 2 pins as follows Ma,Sl,CS. The jumper just pulls off although you may need a small screwdriver or pair of tweezers to enable removal and just slides back on.
Sep 01, 2009 | Computers & Internet
Computers & Internet Logo
328 people viewed this question
Top Cooler Master Computers & Internet Experts
Computer Links
Chris Larocque
Jay Plesset
Are you a Cooler Master Computer and Internet Expert? Answer questions, earn points and help others
