Question about Arris SURFboard SBG900 (49402201900) Modem
Cant login to router
My router wont let me log in. I've already reset it and tried the default username and password. please help!
    Problem Solver:
  • 16 Answers
When in doubt double check your work. You held the reset button down on the back of the router for long enough for the lights to go out then start blinking again? Then you went to 192.168.100.1 in your browser and tried admin for your login name and motorola for your password? If you did all of that and it's still won't accept your login try to power the router off for at least a minute by pulling the power cord and make sure you clear your browser cache before trying to access the default gateway address in your browser again.
Hope that helps!
Jill
Posted on Nov 30, 2008
I have a problem with my router login.I have tried hard resetting it and using the default password (username: admin , password: password) whenever I try to login it gives me an error: "System...
If the router ssid reads virginmedia.... then you have not reset the router. The default name for a Netgear router is Netgear.
Push the reset button in (on the back of the router) and hold it for at least 15 seconds or until the power light flashes.
Now the username and password and SSID should be reset to the default.
Oct 23, 2011 | NetGear DGN1000 Wireless Router
Forgot username & password for netrouter wgr614v7
How do I log into my router?
To log into a NETGEAR router:
  1. In your Web browser, navigate to the router login page. By default, one or all of the following URLs should work:
    • http://www.routerlogin.net or http://www.routerlogin.com
    • http://192.168.1.1 or http://192.168.0.1
    Note: You can sometimes find the login URL on a sticker on the bottom or back of the router.
  2. Enter the username (admin) and the password.
    • The default password is password, or for older routers, 1234.
    • If you have already changed the default password, use the password you assigned the router. Passwords are case sensitive.
    • If you have already changed the password and do not remember it, you have to reset the router to factory defaults in order to use the default password. Resetting a router to factory defaults erases all changes you have made to the router's configuration files.
This information is extracted from www.netgear.com, for learning purpose only.
Hope this will be useful for your question.
Good luck. Remember to rate my answer please.
Jul 13, 2011 | Computers & Internet
I cant login to my routers thing
If you have forgotten your login password:
Perform a Linksys reset
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 24, 2011 | Linksys WRT120N Router
I cant log in with my username and password
Reset the router to factory defaults by putting in a push-in in the small hold at the back of the router. You should then be able to login using the default password. Default password should be in the user manual.
Dec 05, 2009 | Arris SURFboard SBG900 Wireless Router...
I CANNOT LOG IN TO MY ROUTER
You can do a reset on the Router to return to factory default. You can press the tiny reset button using any pointed object or with a paper clip. After that, you can already login to the router using default access. Open http://192.168.0.1 in a browser and use "admin" as username and "password" as your password.
Nov 19, 2009 | NetGear WGR614 Router
Cant login never had username or password if i did i forgot
Depending on which revision you have there are two possibilities
Default Username is: admin
Default Password is: password
or
Default Password is: admin
If neither of these work - you may have setup a new username and password and forgot - on the router you will see a reset point - reset the router to factory defaults and the username and passwords above will now work.
If this helped you then please help me and vote kindly, thank you.
Oct 14, 2009 | NetGear WGR614 Router
Default username and password
username :- cusadmin password: - password
this is the default password, this is for the version 2A , port or protocol = http://192.168.0.1
i think this solves ur issue.
Jun 22, 2009 | Computers & Internet
Username and password
if this is fresh from the box, the factory default will be (username - admin) and the (password - admin). but if this already configured by the user before, all you have to do is restart it so that it will back into factory default.
simply press the "reset button" for 10 sec...
then try to login as a factory default then configure it again
Mar 22, 2009 | Actiontec GT704WG Wireless Router...
Need to get into the router settings , but the default username and password aren't working, I've already held the reset button down for 30 secs and tried login admin:password , but no luck...
Since you already tried steps 1 thru 4, give steps 5 and on a try
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Mar 05, 2009 | NetGear RangeMax WPN824 Wireless Router...
DI-524 problem please help
The default username for this router is "admin" without the quotes, and the password is blank (don't type anything.) If that doesn't work, it may have already been changed, in which case you can soft reset the settings to factory defaults by using the reset button on the back of the box.
Sep 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Arris SURFboard SBG900 (49402201900) Modem Logo
1,026 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
