Question about Gateway Computers & Internet
3 year old laptop computer with motherboard fan failure; can this be repaired?
  • Greg Wilkins
    Greg Wilkins May 11, 2010
    What kind is it? most computer repair shops could do that. I don't know what they would charge thats another thing.Does it heat up? Minde don't work either and it don't seem to effect it any.But today's computers probably get hotter. Mineis an old IBM notebood with a pentium lol. God Bless you Greg
  • Gateway Master
  • 19,396 Answers
Yes, that is an easy repair, but it is better to have it done at a repair shop.
You can buy an heatsink at any repair shop for $10 or $20, and have it installed for $40 or so.
When you buy the heatsink you ask one for your CPU, not the computer mode. You ask for example an heatsink for pentium 4 2.2 Ghz., check what CPU is installed on your PC.
Here is an example:
StarTech.com Heatsink + Fan For 1U Servers ...
$10 to $25 - 109 stores StarTech.com 1U AMD Opteron CPU Heatsink with ...
$23 to $34 - 111 stores StarTech.com Universal AMD 64-bit CPU Heatsink ... $9 to $21 - 93 stores
Posted on Nov 30, 2008
    Scholar:
  • 160 Answers
The fan can be replaced, but it should be done by a tech as it requires experience in opening the case and installing the fan properly. don't try it yourself. the damage you can cause may be worse than the cost of a tech.
Replaced fan compaq presario a900 it will start then says system failure i dont have a disk what do i do
System failure indicates a motherboard problem, If this machine is old, I would think about not putting any more money into it.
Apr 11, 2012 | Compaq Computers & Internet
I am changing the motherboard of my hp pavilion dv7 2173-cl but i've found that the old one was overheated and because of that it broke down. How do i check if the fan still works? besides the rubber (i...
Unfortunately HP has has an overheating problem with their laptops for years. Machines often get hot enough to melt the solder and other parts on the motherboard . This often results in faults ranging from system shutdown to audio problems to complete failure. They have not addressed this issue adequately.
It would be best to replace any parts that show heat damage. You can verify that the fan is working by hearing it run. Also your bios should show if the fan is operational. Alternately, there are several free utilities such as Mother Board Monitor that can monitor CPU temperature, fan operation and system condition.
Don't be surprised if even after replacing the motherboard, the system still overheats. Using a cooling pad and assuring the vents are clean and clear of obstructions may help.
Apr 04, 2011 | HP Computers & Internet
While working on Lenovo y530 --just stops working--screen black --wont turn on again-- computer is not 2 years old--has been to Lenovo for replacement of touchpad ==came back w all my data erased. I...
that's exactly what happened with my Toshiba m35 back in 2008. See if the LEDs blink at all and the CPU fan spins when you try to turn the laptop on. If they do show signs of life and then shut down after a few seconds then probably your Lenovo suffers from the infamous Maxim chip failure. Read through the detailed description of my Toshiba Maxim chip failure and check to see if your laptop has all the symptoms.
The solution is to either get a new motherboard (about $350), or try to resolder the maxim chip, which is not all that difficult as it sounds. You can take the motherboard to a TV repair shop and ask them to resolder it with a regular soldering iron. It's a 5 minute job for an experienced repair technician.
Jan 14, 2011 | Lenovo Computers & Internet
Soyo k7v dragon plus motherboard continuous
2 beeps = memory problems. Since you get them even after the memory has been replaced then the problem is in the motherboard itself. Check the capacitors for bulging. If you can't find ones or you can't replace them then the motherboard is dead.
May 13, 2010 | Soyo SY-K7V Dragon Motherboard
Trusty Inspiron 9100 died suddenly, now won't power up...
Hey,
This could have been a overheating issue thats damaged the components already.
I'm sorry but over the internet I can see what the problem would be, Would need to inspect and test it closely.
I would suggest you get it looked at by a professional, if you only get a recommendation to replace the motherboard and a 200-500 repair estimate I suggest trying another professional.
there are people out there who repair motherboard. I've seen some deals on ebay for repairing a motherboard and it might be cheaper to get the motherboard repaired if its indeed faulty instead of getting it replaced.
Replacement is obviously the easyer process and thats what most professionals offer.
If you are fimiliar with electronics, you could test the fans yourself by taking them out from the computer and giving the required input voltage on the red and black wires. and see if it spins properly.
If it does spin fine but not on the computer, that would suggest a hardware issue on the computer possibly motherboard or other component failure.
But again this is just guessing over the internet without inspecting the laptop.
I'd suggest to find a professional who is willing to look into it in detail without a huge bill.
Let me know if you need anything else.
Thanks,
Ekse
Feb 20, 2009 | Dell Inspiron 9100 Notebook
Here's more info to my problem: Gateway laptop is 4 years old. Now getting message that says "System Fan Error!! !!Please turn off system and checkyour system fan!!" Computer was purchased...
Your CPU fan has failed! your heatsink overheats quickly and then shuts down to protect itself from burning up. Your motherboard is Not the problem, the fan is. This fan can be replaced by any compotent laptop technician. Make sure the tech has access to Gateway or has a source that supplys Gateway parts, as the part must be made for Gateway laptops and your model exactly! 90% of this type of problem can be repaired! Don't let non-techs at Best Buy or any other dept. store tell you your PC is "No Good". Take the time like your doing and do some research the problem before giving your hard earned cash to a 16 year old "Technician/salesman/commision/bonus" person.
If the Harddrive is undamaged and it can be mounted yes, your stuff can be saved to DVD or such. Be prepared though, this type of service can be costly so ask around and get quotes.
Nov 30, 2008 | Gateway Computers & Internet
Lenovo 3000 Notebooks : N100 Power Failure!
Radalin -
I've done a lot of laptop repair, and have run into similar issues with various laptops. What you've described sounds to me like a problem in the power circuit on the motherboard. There are a number of things that can cause this, and, generally, none of them are an easy fix - blown capacitor, bad power IC, bridged leads on a relay. If you have any experience working with integrated circuits, you can always test the power loop on the laptop with a multimeter. However, you may want to look into obtaining a warranty repair, or purchasing an extended warranty so that you can get a warranty repair; if there has been no user error(i.e. fluids spilled on the computer, dropped computer, left in excessive heat or humidity), then its a factory defect on the motherboard.
Hope this helps!
-thinstatic
Jun 11, 2008 | Lenovo 3000 N100 0689 Notebook
Acer aspire 5002wlmi laptop
Use speedfan to see what temps its running at as it sounds like an overheating problem. Is the fan running ok?
Jan 29, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
