TIMER WASHER BROKEN
TIMER WASHER IS BROKEN I NEED A DIAGRAM SO I KNOW EXACTLY HOW TO GET IT BACK TOGETHER DO YOU WHERE I CAN GET ONE?
  • 116 Answers
WHERE DO YOU LIVE ,, GOING ONTO SEARS WEB SITE CAN ORDER ALL PARTS THROUGH THEM ,, TIMER NOT WORTH REPAIRING CHEAPER TO REPL ,,,,,
Posted on Nov 30, 2008
It wont spin or drain. washes fine. checked the lid switch but cant tell if thats the problem or not
This is probably simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the debris trap/filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the debris trap/filter. Depending on the model (not familiar with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 04, 2011 | Kenmore 24032\24036 Top Load Washer
Will not spin
Probably needs new carbon brushes, these are usually easy to find on the internet
Apr 20, 2011 | Kenmore HE2 Plus Front Load Washer
Diagram of#110.26901691 putting unit back together
Go to searspartsdirect.com and type in the model number you provided. There are various exploded view diagrams of your washer that you can reference. They are broken down by section.
The trickiest part of repairing this washer is how to remove and reinstall the washer cabinet. The following link explains how to properly access the washer interior and how to properly reinstall the case when repairs are completed:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you still require assistance, please post back and let me know what you are attempting to repair/replace and the problems you are having. I hope this helps you.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Timer knob assembly, how to disassemble and assmble back together
It sounds like the only thing you are missing is the circlip to hold the whole lot together.
With it de assembled you should see a cut out part on the timer stem that's where the circlip goes when it's all back together
Jun 11, 2009 | GE Washing Machines
Whirlpool Washer Model:LSN1000KQ0,SER: CM4267948, Type: 111 - Need nylon gear in transmission gearbox.
From the information provided, it sounds like you need WPL 285362 (gear and pinion kit) which you can find at appliancehelp.com for $59.95. You can type in your washer model and see the diagram of each part before ordering so you get exactly what you need.
Apr 16, 2009 | Whirlpool Clothes Washer Timer Knob -...
Reinstalling a key cover
I know these can be a bit frustrating, but you're just going to have to keep working with it untill it snaps in properly. Unfortunately there is no diagram for these, if you're unsure that you have it together right, I suggest taking another key off to see exactly how it goes together.
Jul 18, 2008 | HP Pavilion zd8000 Notebook
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
All my washer will do is spin no matter were In set it
The timer contacts have welded together. Replace the timer.
Jan 11, 2008 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
