Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer Tub Fills With Water When Washer is Not On
My Kenmore has been working fine for over 1 year. Now, when the washer is idle and not in use, the tub fills with water and gone unnoticed overnight, flooded the laundry room and adjacent hallway. When we checked inside the washer, it was still half full of water. It drains normally and washes normally. Any ideas? Thanks
  • Patty Fowler Jan 22, 2007
    It is Kemore Elite HT3
  • wtplvr1 Jan 17, 2009
    Our washer is doing the same thing now. its a Kenmore Elite HE3 model # 110.45872.400.
    President:
  • 878 Answers
Dtfpaf, you need to replace the water inlet valve. Easy job, post the model number and we'll get you a part number...Catriver post back.
Posted on Jan 21, 2007
SOURCE:
Washer starts to agaitat before tub fills up
Kink or blockage in the hose from the tub to the water level control probably where it connects to the tub Or the water level control is bad.
Nov 29, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series heavy duty washer
If it fills up to normal level on other settings then the water selector switch is bad.
Look at the back side of this switch and you should see a tube connected from the switch to the lower part of the tub. Take the tube loose at the switch and blow through to check for any blockage. Look at the tube for holes.
Nov 14, 2008 | Kenmore 22422 Top Load Washer
I suspect you have a water inlet valve problem. When the valves fail, they tend to either leak by, or do not open at all. The symptom you are describing is typical of an inlet valve that is not closing properly. The leak may be minute, but over time, it fills the tub and over flows. To access the water inlet valve, you will need to remove the washer top panel. Remove the three screws in the back that hold the top in place and slide the panel straight back and lift off. The water inlet valve will be located on the left hand side in the rear between the fill hoses and the dispenser (as viewed from the front of the washer). If you wish to perform this repair yourself, you can find the part at searspartsdirect.com. Just type in your complete model number and the part can be located on the next page under the "Dispenser Parts" section as item number one (part #8181694). The replacement process is very simple. Just turn off the water source, remove the fill hoses, the dispenser hose and the mounting screws. If you need further assistance, please let me know. I hope this helps you.
Jul 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore top load washer leaks as it fills and drain hose is not an issue. There is a small hole in the plastic hosing where the two hoses meet, but why is water even getting to that point when it should be...
As the washer fills the water will go up the drain hose to the same height as the watr fills in the tub. That is why the drain needs to be higher then the tub or the water can just run down the drain.
Apr 25, 2008 | Washing Machines
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
240 people viewed this question
Sal De
fordexpert
yobo007
yobo007
