There are two clips for each light; one to each side just lift up on the clips. Then you have four upper and two lower grill clips that are the push/pull type. Just pull where the clips are located and they will pull right out. Watch for stressing the wiring going to the running lights. You then can pull the headlight grill assy out far enough to change the lights. Low beams are to the outside and high beams to the inside. DON'T TOUCH THE BULBS!!! A little twist left or right will unlock the bulbs. Use some contact grease to make sure the contacts stay good. 15 - 20 minute job.
It doesnt take special tools to do that. You might have to buy a couple of tools, but it wont cost much. Its relatively easy taking out your headlights.
How you do you replace a headlight on a 2004 TrailBlazer? Can't seem to get the plastic cover off?
how do u change headlight
