Question about Toshiba Satellite A105 Notebook
Restoreing back to brand new
My friend has a toshiba satellite a55s106 and is trying to restore it back to the way it was when she first purchased it....how can she do this>?
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
Sep 26, 2011 | Computers & Internet
Is there a way to restore factory settings (out of the box settings) for the Toshiba Satellite A65-S1062?
Hi blackrose696. There's 2 ways. 1.- If you go to My Computer and see a partition (probably D:) called recovery, go to Start - All Programs - and see if you see under Toshiba - something called recovery or restore (you WILL loose ALL your data) and follow the instruction. If you DO see the partition but you dont see anything under Toshiba folder, then restart the computer and inmediately you will see something like Press F10 or F12 to boot from recovery partition.
If you dont see the recovery partition. The only way is using the Restore CDs... if you dont have those you have to order them from the Toshiba website. (they cost like $15) so that way you are sure you get the license and the drivers correctly. I hope this helps. Please do not forget to rate and provide positive feedback from our support today. Thank you :D
Apr 30, 2010 | Toshiba Satellite A65-S1062 Notebook
How do i set my toshiba satellite pro L300 back to factoery settings
Put the original restore CD into the drive and restart the computer. It will then go into a "restore mode" and allow you to erase everything and start it over like it was brand new again. If you don't have the restor CD then you could use any copy of a Windows Operating System (XP, VISTA, 7) to reset it all
Dec 25, 2009 | Toshiba Satellite Pro L300-EZ1005X...
Where do you go to do a system restore on Toshiba Satellite A135 laptop? Other laptop system you might go to start menu and then click on help and you can do a system restore there or you go to control...
it depends on your operating system your using ex. windows xp pro,windows 98SE,vista,linux,ubunto...in xp click start-all programs-accessories-system tools-system restore from their choose a restore point to an earlier time before that problem occurs
Nov 03, 2009 | Toshiba Satellite A135 Notebook
Toshiba Satellite P105-s6147 CD/dvd drive some how uninstalled
Registry edits not usually a good idea. System restore is your friend. Some DVD burning apps will change your registry and cause the CD/DVD to disappear. Uninstall the new burning app, or system restore to a time you know it was working.
Jul 24, 2009 | Computers & Internet
Cant log in to Toshiba A300-1J1
What I would suggest is logging on in safe mode and trying to restore it to an earlier date using system restore. likely the profile is corrupted. By doing a restore back about 4 to 7 days , or before this started happening, will likely fix your issue. If not you will have to purchase the restore cd from toshiba or restoring it from a recovery partition if it has one.
Jul 03, 2009 | Toshiba Satellite Laptop with AMD Athlon...
NO SOUND ON MY TOSHIBA LAPTOP
You can try a system restore, ie you can take back your computer to a date when it was working fine .
Running system restore in windows Xp:
Start >All Programs> Accessories >System Tools >System restore
Running system restore in Vista
Start> write "system restore in start search bar "> click system restore
If the system restore doesnot work , try uinstalling the sound drivers from the add remove programs and install the new ones from the link below
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-A25-S207/download/page,sh,30994,221,19,.html
Thanks
proton
Jan 10, 2009 | Toshiba Satellite A25-S207 Notebook
My friend has a toshiba a55s106 satallite.....and need to find out how she can restore it back to when it was first purchased?
Hello there :
Yes it can be restored ONLY if you have the original restoration cd that came with the computer i have the same computer and i have done this with it and it worked good if ytou dont have the cd contact www.toshiba.support for phone numbers and technical information
Nov 30, 2008 | Toshiba Satellite A55-S106 (PSA50U0NE02E)...
Toshiba Satellite A105 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
