Question about HP Pavilion a810n (PP164AA) PC Desktop
Blue screen when starting up
When starting the computer the normal HP Blue Screen opens with the , , options on the bottom of the screen, however the computer will not get past this screen and the options on the bottom of the screen will not work. Seems like the computer doesn't want to get going or is locked up somehow. I have tried starting it over and over, unplugging all cords and unplugging the power, all with no luck. Any ideas of what might be going on?
  • 50 Answers
Resolving the blank screen issue Follow the instructions below in order to fix this issue: 1. Remove any CDs, DVDs or memory cards from the computer. 2. Disconnect all devices from the computer leaving only the original mouse, monitor and keyboard and power cord connected. 3. Restart the PC. 4. Press the F1 key repeatedly during the first startup screen until the entering setup message appears. 5. Press the F5 key to restore the default settings. Use the arrow keys to select YES and press ENTER. 6. Press the F10 key to save the changes and exit. Use the arrow keys to select YES and press ENTER. The PC restarts. 7. When the system restarts select Last Known Configuration from the boot menu. The PC should now startup normally. If the blank screen persists continue with the following steps. 8. Select Safe Mode from the Windows Advanced Options Menu. 9. Use Microsoft's System Restore feature to restore your computer to an earlier time and correct the issue. If the blank screen persists or it is not possible to enter Safe Mode perform a system recovery Perform system recovery by visiting the given link for the steps. http://tinyurl.com/2hsjug To let you know I got this information from one of the geeks from ***
Posted on Jan 23, 2007
I had the same problem. I was going to replace the motherboard. Checked every connection on motherbaord, including reseting the processor. So far it is now fixed. Will wait a while and look for more solutions before turning it off again. Good luck, please report if you find the problem.
Posted on Jan 22, 2007
    President:
  • 2,961 Answers
Just double check the keyboard connection if it's ps2 type connector; if it's a usb mouse it won't work cos the drivers have not loaded. Only other solution is to remove right side panel of pc and locate the JBAT1 terminal and move jumper from pins 1-2 to pins 2-3 for a few seconds and back again. Turn on pc and then hopefully you can access the bios to set the time and date and save settings then re start.
Posted on Jan 21, 2007
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
I have an HP Mini 110-3135DX. When I turn on the power all that is displayed is a blue screen and it wont boot. How do i fix it?
check you bios pages are correctly configured,,goto bios navigate with "tab" and arrow keys,,play around untill you know these pages dont change anything untill you are sure you know what you are doing..Exit and save pay attention to boot sequence if this is set up wrong it might cause failure in the way you describe,the instructions on the right hand side of the bios pages should help you---good luck --Davey
Jun 20, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
Compaq sr1500nx reads NTLDR is missing
boot from your install disk and open CMD, from there use /bootsectit will give you your options
May 03, 2012 | HP Compaq Compaq SR5502FH-E Presario...
How do I factory restore my HP Pavilion dv4-2112TU with the recovery menu, safely.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
helps don't forget to vote
Feb 28, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
HP505N. Kids messed with computer and it shut down. Now it's stuck on the blue HP screen. F1 comes up with the entering setup box but nothing happens. F10 and using the system recovery disc won't work...
pres f 9 to choice boot menu. Or go F 10>go bios for set boot piority>and F 10> yes enter.if not work please re install xp .and create partion again ,because your kids can be delete the partion file (ntldr/boot.ini).
Nov 21, 2010 | HP Pavilion 505n (DC470A#ABA) PC Desktop
I have a HP Touchsmart IQ500 that is a little over a year old. It was working fine and I went out one day to come back and start it up to find it was only a blue screen with a few options.I found someone...
This might be an issue with the Hard drive or the operating system installed on the hard drive.
Try to access BIOS screen tapping on F10 on restart.
If you are able to access Bios try to run the Short smart self test on the Hard drive.
To run the test follow the steps as follows:
on the main window you will see 1 st drive 2nd drive 3rd drive 4th drive.
besides these drive letters you will find your Hard drive listed.
Highlight that and press enter.
on the next screen highlight Smart support and press enter.
on the next screen select Short smart self test and run the test.
If it gives an error code that means the hard drive has gone bad.
2)If not then come back on the main page by clicking on ESC button till you come back to the main page.then Press F5 select yes to load set up defaults and press enter.Press F10 once to save configuration changes and press enter.
It will boot to windows.
3)Still if you face the same issue then you need to perform the recovery using the recovery cds.
4)If you don't have the recovery cds then you can contact HP support and order the cds and perform the recovery.
This should resolve your issue.
Thanks.
Aug 20, 2010 | HP Computers & Internet
Upon turning on my HP Pavilion Media Center it freezes at logo.
press F10 and format the pc with inbuild pc recovery and if it does not works then format your pc using the recovery discs given to you by HP.
Apr 15, 2010 | HP Pavilion Media Center TV m7360n...
Takes 15 mins to boot after loading Micro trend
you have too much at startup. thats the programs the computer starts at boot up.i would go to last good configuration and see what happens if that works i would seriously get rid of some programs you don't need and defrag your computer.
Dec 15, 2008 | HP Pavilion a1600n (882780776265) PC...
Compaq Presario Disk Boot Failure, insert sytem disk and press enter
If you have your original Windows install disk, you can boot off of that, and should be able to recover most of your files, assuming your drive has not died fully. Depending on how important your files are, you can send the drive to a drive recovery service. I did that a couple years ago, they were able to recover all my files but it was EXPENSIVE. $1200.
Feb 19, 2018 | Computers & Internet
Computer won't boot up
you must hold down the F10 key( for system recovery) when you turn on computer. hold down as computer starts up,hopefully it will then repair itself and boot up. If not,start up computer holding down F12 for advanced diagnostics and run some test!! Good luck
Mar 06, 2008 | Computers & Internet
HP Pavilion a810n (PP164AA) PC Desktop Logo
297 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
