Question about Mitsubishi WS-55513 55" Rear Projection HDTV
How to remove dm module from mitsubishi ws-55513
We have the famous flashing green light. I am trying to get the dm module out and I am not sure what all needs to be removed to get it out. There seems to be something in side the silver case in the back that is holding it onto the bottom and I can't get enough clearance on top to get it off.
help
  • 1694 Answers
SOURCE: mitsubishi WS-55513 won't turn on
Two choices =
1) Replace DM MODULE. 650.00 is right.
2) Rebuild DM MODULE. Done right = a little less than Mits.
Caution: High degree of skill needed and ask about warranty
in either choice.Rebuilds usually cover only parts installed,
not complete module.If you do the research on repair,you
will find pin push reset does not work,in most cases....T.
Posted on Nov 05, 2007
  • 1694 Answers
SOURCE: Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WS 55809 Rear projection TV
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Posted on Jan 24, 2008
  • 1153 Answers
SOURCE: Mitsubishi WS-65611 Blinking lights.
You are probably talking about the FMT board. I think you can have this board repaired at PTS 18008447871
Posted on Mar 13, 2008
experttv
  • 203 Answers
SOURCE: I got a Mitsubishi WS-55513 55 in
What does the set do when you try to turn it on? What does the led light on the front of the set do?
let me know so i can help
Tim Nolan
Posted on Sep 17, 2008
Blinking green light
Common problem with some capacitors blowing in the DM module. Its a failry easy fix if you have the right parts and insructions. Goto www.tvrepairkits.com and get their blinking green light kit.
Sep 23, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Green light flashes under timer when tv is turned on. no picture
Sounds to me that the DM is the cause. If this model is 7-8 years old, it uses a DM that is no longer available or supported by Mitsubishi. You could confirm this by calling Mitsubishi at 1800-332-2119. This is there Customer Service Line.
Hope this helps,
Skyassoc
Jul 18, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Wont power up , green indactor light wont stop flashing
You have four capacitors bad on the "DM" module in the unit. I recommend you get a tech to do this repair. This is due to the complexity of accessing the DM module. A qualified tech can do this repair in under an hour. You can find a tech in your area by inputting your zip code on the home page of this website. Let me know if I can be of further assistance
Jan 11, 2009 | Mitsubishi WS-55513 55" Rear Projection...
http://www.chrisandnat.com/projects/BlinkingTV/Blink.htm
Sep 02, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-55513 blinking power light
The infamous flashing green LED problem is usually due to a failing or faulty DM board. I purchased the PDF manual online and was able to locate and remove the components as necessary.
If you can solder, and are semi-proficient with electronics it is 4 bad capacitors on the DM board...
Otherwise there are facilities that can repair your failed board for about 275.00 or replacement of the board is between 350.00 and 500.00 buck USD.
Good Luck with your repairs....
-Richard (MetalDad)
email: PentiumDreams@aol.com
May 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
replace DM
Picture of bad caps
Jan 16, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Ws65813
Check threads for DM repair or ctechnicians.com
Jan 04, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 won't turn on
from what i know thru extensive research.....and i mean alot the dm board (as in the whole thing) is not all bad its thecapacitors on the dm board that are supposably cheap O'z if you know what i mean. there should be 4 of them. you can buy the replacemnets from radio shack for about 8.50. if you know someone who is handy with a soildering iron, or a freelace electically type then ask them if they can put the new ones on for you. the correct one you need are -40 degrees to +85 degrees Celceus...tolerance +20%, now this is important 1000microfarad.... now these capacitors cant be less than 16V they can be over but not under.... typical brand to get is xicon....you have to remove the dm board which is in a metal shield once the back part of the television is removed you will see it cause it looks like it should be in a computer. but apparently this is typical and its a very simple fix but everyone that is capable to fix it want to bend you over and do you dry....mitsubishi should be ashamed of themselves for not correcting this themselve and offering help with cost.. hope this helps guys!
natalie
Oct 21, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
