Question about Lexmark X4270 All-In-One InkJet Printer
Line on scanned copy
There is a line going through the copy when it pulls up on the scanner. I have tried cleaning the connectors to the ink cartridges with alcohol, but it is still doing it. Help. Thanks.
It want work with window vista
Posted on Nov 30, 2008
When I run anything through the rollers I get a black line down my copy/scan. How do I fix this? I have cleaned the rollers and it didn't fix my problem.
only thing I know is when my copier/printer was doing this it was from refilled ink cartridges. if you are using refilled try replacing with new ones.
Sep 22, 2015 | Epson WorkForce WF-3640 Wireless Color...
Black line on copy
Lines on scanned or copied pages is usually caused by ink and trash on the scanner glass. Check the glass on your printer for something blocking the light on the scanner. Here is a link to an article about this issue and where to clean.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
Aug 21, 2012 | HP Officejet 5610 All-In-One InkJet...
Everytime I fax something on my HP Officejet 5610 all in one, the recipient receives the document with a line going down the left side of the page. How do I get rid of the line?
Lines on scanned and copied documents is usually caused by something on the scanner glass such as ink, correction fluid or trash. Open the top of the printer and clean the scanner glass surfaces with windex and paper towels. See this article for more details:
Jun 26, 2012 | HP LaserJet 3050 All-In-One Printer
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
We have a red line thru our scans? I have cleaned everything it says to clean?
red line? this is a black & white
is the line apear only when you scan ?
try and make a copy of the glass if you do not see line .than you problem is that **** glass that scanner uses.IT MAY HAVE WHITE OUT OR INK CLEAN IT .it long thin along the the paten glass
hope that help
Nov 13, 2009 | Kyocera Copystar CS-1820 Black and White...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
White lines across my scanned images
I had the exact same problem! the problem seems to be with the CCD calibrating itself before it starts to scan.
If you look into the scanner, the scanner glass extends itself into the casing of scanner where the CCD rests. Every time before the scan starts the CCD starts to calibrate itself in its housing before it starts to scan. If there is any reminiscence of dust or anything object (like a piece of paper) stuck in the edges where the CCD rest, the white balancing is thrown off and it causes white lines to appear along the entire line where the dust was present.
Ideally the solution would be to open the scanner casing to clean the housing where the scanner CCD rest. This would solve the problem.
If you are unable to open the scanner casing, then try using a piece of paper or a thin edge of a cloth, slightly dampened to reach into the edge of the scanner glass where the CDD rests and clean it. This is what i did and this solved the problem.
Jul 09, 2009 | HP PhotoSmart C4385 All-in-One Printer
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
Facing copying problem from scanning section
Although you didn't specify the scanner model, this solution should work.
If the scanner has a top feeder, open it.
You will see a thin strip of glass, either to the left, or right of the large scanner glass.
There is most likely a small spec of ink, white out, etc on it.
Clean the strip glass with rubbing alcohol and the line should go away.
Apr 09, 2008 | Office Equipment & Supplies
Canoscan 9950f red line on scan
Try running a calibration. This is done thorugh ScanGear in Advanced mode. Once in Advanced Mode, in the Image Settings section there should be an option for Calibration (you may have to scroll down in this section to see it). After running the calibration, try performing a preview scan with nothing on the scanner glass. If the red line shows up on the preview now, then most likely the scanner needs to be serviced.
Mar 12, 2008 | Canon CanoScan 9950F Flatbed Scanner
Lexmark X4270 All-In-One InkJet Printer Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
