Question about Craftsman 4 Cycle Blower/Vac
Can't get spark plug out
I have a Craftsman blower mulcher and it says to use a 3/4" socket wrench to remove the spark plug but I can't get it doesn't seem to fit. Is there another way to remove it?
  • 163 Answers
If your using a spark plug socket, theres a rubber grommet inside to protect the ceramic plug. sometimes they can be a tight fit to seat properly.
Posted on Nov 30, 2008
CHANGE SPARK PLUG ON TORO CCR 3650 SNOW BLOWER
First disconnect the spark plug wire from the spark plug. Then use a socket wrench to remove the spark plug. Install the new spark plug into the cylinder head and reconnect the spark plug wire. The Toro CCR 3650 uses a NGK BPMR4A plug gapped to 0.032".
Jan 25, 2016 | Toro Garden
How do I replace the spark plug
it takes a spark plug socket which is deeper than a normal socket you can get one at sears just ask them for help and they can show you which one you will need to remove the plug remove the rubber cap place the socket on the plug and in a counter clock wise motion remove the plug replace as needed then switch the wrench to tighten and in an opposite motion clock wise tighten just snug carefull not to over tighten just snug will do
Dec 04, 2014 | Garden
Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Oct 12, 2012 | Craftsman Garden
My echo backpack leaf blower pull start seems stuck it wont crank
Without getting to involved with it, did you always mix the correct fuel/oil ratio? or has someone else possibly put straight gas in it without oil? Another possibility is that the recoil could be broke. I would try to determine if the piston is seized in the cylinder. First remove the spark plug and try to pull the starter rope while listening closely for any strange noises from the engine. If it pulls fine then, replace the spark plug and try to start it again. If that doesn't work then I would remove the back cover and remove the muffler so you can look at the cylinder. You will need a phillips screwdriver and a set of metric allen wrenches. Hope that helps.
Aug 30, 2011 | Echo Pb - 413t Backpack Blower
Cant start my craftsman leaf blower
Chances are your carburator has dirt in it.
It doesn't take much to clog those little carbs.
Empty the gas tank and clean it.
Purchase a can of small engine carburator cleaner. Comes in a spray can for about $5 at Home Depot or Lowes.
Remove the carburator and disassemble it.
Soak the body in clean gasoline for about 15 minutes if you can, agitate it to help the gas disolve any clogs.
Clean the ports with the spray cleaner to blow out any debris.
Reassemble and remount the carb.
Remove, clean and gap the spark plug
Refuel the gas tank with new clean gas
May 16, 2011 | Craftsman Garden
Craftsman gas blower no start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 25, 2009 | Craftsman Garden
My craftsman leaf blower will not start.
Basics to check:
- aluminum or silver - piston/cylinder scored
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Oct 30, 2009 | Craftsman 4 Cycle Blower/Vac
This Model 358-797251 Leaf Blower will not start. What can I do to make the engine run at the regular speed?
Basics to check:
b) is there spark
1) spark plug
Remove Carburetor
Oct 19, 2009 | Craftsman 4 Cycle Blower/Vac
Will not start
Basics to check:
b) is there spark
My craftsman leaf blower wont start
HI THE FIRST THING TO DO IS REMOVE LEAD OFF SPARK PLUG TOP THEN REMOVE SPARK PLUG ITSELF YOU WILL NEED A SPARK PLUG REMOVER OR A SOCKET TO DO THIS AFTER REMOVING THE SPARK PLUG CLEAN OFF EXCESS OIL BY DIPPING IN CLEAN PETROLAND CLEANING WITH TOOTHBRUSH LET DRY THEN WITH A FOLDED PIECE OF WET AND DRY SANDPAPER GENTLY RUB BETWEEN THE SMALL GAP AT END OF SPARKPLUG THEN REPACE SPARKPLUG AND IN MOST CASES IT SHOULD START FIRST GO BESTALUCK GLENN
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
233 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dwain Pippen
Jim Parker
Jim Parker
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
