Question about Brother SE-270D Computerized Sewing Machine
Safety Device Activated
I was in the middle of sewing a overcast stitch on my Brother Innov NX 400Q and the machine locked up and displayed "Safety Device Activated". I have had this machine for about 2 years and sewed very little on it as of today. I followed the instructions in my manual. I also checked the bobbin case and removed the plates and bobbin holder and cleaned with the lint brush. I rethread the top and reinserted the bobbin. I had to manually thread the needle (also changed the needle) and I still cannot move anything to sew.
5 Suggested Answers
  • 323 Answers
SOURCE: Brother 2001 sewing and embroidery machine.
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
sewman7
Posted on Jun 18, 2008
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
  • 1788 Answers
SOURCE: Brother PC-420 Error Message: The safety devise
Go to brother-usa.com and download a manual or call their customer service. Phone number is listed in the website
Posted on Aug 31, 2010
SOURCE: Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Posted on Oct 30, 2010
I have Innovis 6700D. My problem is the machine stops and the screen flashes " lock down hoop" (when it already is). Then the needle jumps to the side. Are you able to help? Thank you. Veronica
That sounds like it is a safety feature being activated. Quite possibly the machine is not recognizing the hoop is locked down or the hoop is not tight (a malfunction) although it appears to be installed correctly.
FAQs Troubleshooting Innov is 6700D United States Brother
Jan 21, 2018 | Sewing Machines
Set my machine to get a 1/4 seam on the right side? For quilting
If you're using the straight stitch you need to increase the stitch width which moves the needle to the right. On the arrows keypad click the right side arrow then press the Manual memory key.
If you have the manual for your machine, go to page 64
Sep 29, 2014 | Brother Sewing Machines
Safety device has been activated
The stitches for zig Zag and all utility stitches are upside down. The zig zag is on under side?
Jan 09, 2014 | Brother SE-270D Computerized Sewing...
Brother SE-350 "The safety device has been activated"
Return the bobbin winding shaft on the top right of the machine to the Left Position. It may be stuck in the middle.
I had this same problem. After an hour or two of fiddling, this fixed my problem.
Dec 22, 2009 | Brother Sewing Machines
Brother 270D Jams when sewing anything
You might have thread caught in the take-up lever linkage and it has soaked up all the oil my recommendation would be take it to your local dealer
Jun 24, 2009 | Brother SE-270D Computerized Sewing...
sewman7
Jun 16, 2008 | Brother Sewing Machines
Brother SE-270D Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
