Goodman GMS81405DNA. 3 Blinks indicate a Pressure Switch Problem. Usually water in the hose, but not this time! When I remove the hose, and draw air through it myself, the furnace fires. The Recirc Motor feels like it's BLOWING air out, and not drawing it in! Any ideas? Mark
  • mrfyvie Nov 30, 2008
    Did not appear to be, and the vent blower rotates freely with abundant speed.
    Will check my Exhaust Flew tomorrow. For now I'll sign off untill then. Thanks so much for getting back to me, and I'll do the same later, Mark
  • 182 Answers
Id say your flue exhaust pipe is restricted.
Posted on Nov 30, 2008
  • Dave Dobransky Nov 30, 2008
    If the fan is spinning and the pressure switch is ok....its either flue or heat exchanger with a big hole.
Goodman Gas Heating A/GPG13 Not Heating - Pressure Switch Stuck Open
Clear the little hole where that hose go to the inducer case
Feb 10, 2013 | Goodman Manufacturing Goodman...
My Goodman furnace, model GMS80903BNA, is not working. I removed the back panels and checked the pressure switch. That seems to be working fine. The exhaust inducer spins up, the igniter starts to glow,...
That blinking 3 times is indicating a pressure switch problem. Try checking for water or a blockage in any of the hoses going to the pressure switch or condensate drain. Check the air intake and exhaust pipe for any blockage including any saggs that may hold water. Make sure condensate drain or pump is working. If you get a glow from the igniter, there may be a blockage in the gas valve or piping.
Jan 23, 2011 | Goodman GMS80903BNA Heater
I have a gmpm100-4 furnace. The problem indicator lights blinks three times. It indicates a pressure valve is not closing. Question, what is the pressure valve and or switch that regulates this process and...
It may look like a small round disc and is connected to the inducer or exhaust fan by one or two small hoses. Make sure the hoses are free of any blockage, the air filter is clean, any hoses for the condensate drain is free of any water blockage, make sure your condensate pump is working (if you have one) or that the main water drain is not obstructed. Also inspect the fresh air inlet pipe and exhaust pipe for any sags where water can collect or any other blockage. If you find no blockage anywhere, replace the pressure switch. You may even have to remove the inducer fan to inspect for blockage. If you remove the hoses off the pressure switch, you should feel a small vacuume being produced that closes the pressure switch. If you feel nothing, you have a bad inducer.
Good Luck.
Jan 20, 2011 | Goodman GMS90703BXA Heater
Light blinks 3 times on a Goodman model gmh80453an
Three blinks is an indication of a pressure switch error. Check your air filter, condensate pump or drain, vent termination and air intake for blockage or debris. Also check the inducer housing assembly for a build-up of water. Pull off the hose(s) going to the pressure switch and clear out any moisture. You may be able to jump out the pressure switch only after the inducer starts blowing to test it. If it starts, the switch is bad. If your venting runs horizontal for any length, make sure there is no build-up of water in either pipe by tapping it and listening for a thud. It should sound hollow and echo when you listen. If you **** in on the pressure switch very lightly, you should hear it make contact and you can test it with an Ohm meter for continuity. Hope this helps!
Jan 18, 2010 | Goodman Heating & Cooling
The led light blinks 3 times then pauses then
Pressure switch error code, Check the air filter for blockage, check the vent pipes for blockage or water, make sure the condensate drains are working and that there is no water in the hose(s) that go to the pressure switch(s).
Jan 06, 2010 | Goodman GMS90703BXA Heater
Three blinks on gas furnace, will not maintain flame
3 blinks indicates a pressure switch error. Check or replace air filter, condensate hoses for blockage, check small hose uo to pressure switch(s), check the vent pipes to make sure they pitch back to the furnace, check the air intake and exhaust pipes for any blockage outside. If all looks good, jump out pressure switch as soon as the exhaust fan starts to turn and see if unit starts. If it does, replace pressure switch.
Dec 01, 2009 | Goodman Heating & Cooling
Need to find the pressure switch on my goodman furnace
It's mounted onto the gas valve. It will be a button or lever that you have to push in or down, depending on the style.
Nov 20, 2009 | Goodman GDS80904BNA Open Flame Heater
Furnace gms90904cxa I have 3 blinks what s the
Pressure switch is not working, plugged air intake or exhaust pipe, dirty air filter, debris in condensate hoses, debris in pressure switch hose.
Oct 18, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
Goodman GMP125-5 furnace burners won't fire
Try to bypass the connection of the pressure switch to confirm if the pressure switch is really bad, and reset the unit. Monitor your pressure to be sure that its normal and not the cause of tripping your pressure switch.
Mar 18, 2008 | Heating & Cooling
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
