Question about Whirlpool GU2400XTP Built-in Dishwasher
Water not heating up and heating element not heating up either. Water is hot when coming into dishwaher.
    President:
  • 878 Answers
DSBELL, see if your model has a serial number in the range of FR3701001 to FR5008380. If so they had a quality issue with the heater. The element itself should be round and not angular. Call for service, it will be covered. If this is not the case you will have to ohm out the heater, should read between 10 and 30 ohms. If that's ok, make sure the door switches are operating ok, this heater runs through the nuetral side of that door switch. There is also a high limit thermostat on the right side of the motor that should read closed. Catriver...post back.
Posted on Jan 21, 2007
Why when I turn the hot taps on I get milky water out of the hot taps and its a new HWS Vulcan 250 lit electric single element only 3 months old
Put that water in a glass and let it sit for a couple of hours. If it clears up, it is air bubbles. The old unit most likely had mineral deposits on the elements and they insulated the water from micro heating that creates the bubble. Since the unit is new, the water is in direct contact with the heating elements and micro bubbles are forming on the elements. When you turn the hot water on, the turbulence washes the bubbles out.
Sep 04, 2016 | Water Water Heaters
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
Bought reliance 602 50 gallon electric hot water heater 4 years ago and it stoped heating bought new upper and lower elements and new upper and lower thermostat and still no hot water power goes to all...
did you turn the breaker on ? before filling the tank ?the water tank must be completly full before turning on. the new elements will blow if not submerged in water ..if you have 240 volts at the element and its not heating one is out .only one element can be on at a time so you really need an amp prob to test element .try an ohm meter an check resistance ,sounds like one element is out .hope this helps good luck /P/Swhen filling tank. open a hot water valve, on tub or faucet to remove air while filling the tank. you will hear the air coming out of faucet. when water comes out its filled..
Aug 23, 2010 | Heating & Cooling
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Dishwaher water does not get hot enough
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
iueyj
May 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Heating elements do not operate together
That's how they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank
Mar 28, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
No hot water, plates cold and dirty and wet
If you've installed it recently make sure the hot water tap was plumbed in and not the cold water tap, check the hot water tap temp in the house to make sure it's getting warm, there also should be a heating element located inside of the dishwaher that heats up to help the dishes dry at the end of the wash cycle, which is controled by a thermostat. If the heating element or the thermostat are bad your dishes won't dry.
Mar 25, 2009 | Miele 24 in. G638 Plus Free-standing...
No hot water
If the water does not heat, then you have to troubleshoot to find the problem. With a voltmeter determine if 240VAC is actually getting to the water heater. Take care here - a defective circuit breaker can give a false 240 volt reading - check for the 240 volts across the upper element (i.e. when the 240 volts has a live load on it, not just an open circuit test).
Also, remember, the upper element has priority over the lower element, and if the water is cold, the upper element will try to turn on and this locks out the lower element (only one element is allowed to heat at any given time). The lower element comes on ONLY after the upper thermostat is satisfied. Therefore if the upper heating element is burned out you will never get any hot water. If you suspect this, TURN OFF THE POWER TO THE HEATER and take a resistance check of the upper element.
Nov 15, 2008 | Water Heaters
Whirlpool GU2400XTP Built-in Dishwasher Logo
116 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
