Question about Mitsubishi VS-60601 60" Rear Projection Television
Push Power button, green light goes on for a few seconds then nothing....
I started by looking at the fuse right next to the power cord where it meets the circuit board inside the tv housing. The 125V 5A fuse was burnt out. I replaced this fuse. I tried again but same thing - push power button, little green light goes on in the front for a few seconds but then goes off and no picture or anything.... Any suggestions?
    Problem Solver:
  • 12 Answers
I would suggest taking a look at the power module if that can be replaced. The Fuse blowing may have only been the beginning of the problem. Any recent issues with under or over voltage in your home?
Posted on Jan 22, 2007
Mitsubishi rear projection tv.. 55 inch made in june 2003... will not turn on... no lights blink nothing no sound.. push button nothing happens.... looked in back not knowing what to look for or look at...
IF power light on front comes on for a second or two and goes off do the self check this set has:
On front of set when power light goes off, press and hold both the Input and Menu buttons at the same time for more than 5 seconds and release both buttons.
Power light should blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat the code four more times.
If this information helps and you want to know what error code found means rate this solution as very helpful and comment here and I will tell you what it means.
SD TECH
Aug 22, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Green light comes on for a few seconds then turns orange
If you have a popped cap then the mosfets are blown. They blow as soon as the cap shorts and pops. You need to replace both mosfets and the 220uf caps and test the fuse with a multimeter I would bet its blown too.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 17, 2009 | Acer AL1916W 19" LCD Monitor
RCA 61 INCH REAR PROJECTION MODEL # P61929 PUSH
The first place to start is the outlet and check to be sure it has power. The next is to check / replace the main internal (to the tv) fuse - it's a 5A 250V GMA fuse (google image of GMA fuse). To find the fuse, unplug the set and remove the back cover of the TV - follow the power cord to where it enters - the fuse is located to the right and slightly ahead of where the power cord is attached to the board.
Nov 08, 2009 | Televison & Video
No Power
try changing to a different wall outlet, nothing to do with the battery
Jul 30, 2008 | NEC PowerMate ES SlimLine PC Desktop
Won't Start
BLOWN YOUR FUSE NEED NEW FUSE IN THE POWER SUPPLY
Jun 30, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
PS2
Faulty button, fuse. Try a new power cable, if that doesnt work then it will need a new on/off switch.
May 16, 2008 | Sony PlayStation 2 (PS2) Console
Wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
198 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
