Keys on Casio keyboard are inoperative
There are 8 keys in sequence that sound only once when my Casio keyboard is powered up, then they won't sound again until the unit is powered down and then powered back up. When it is powered up again, the same keys become inoperative after they are struck once. I have two WK-3000s that developed the same problem about 30 days apart. The second keyboard's malfunctioning keys are at a different octave than keyboard #1 above.
  • ginocumbe Mar 08, 2009
    I have a Casio WK-3500. I have a similar problem. When i turn on the keyboard, there is a particular block of keys that when struck, they only play once... then maybe after 30seconds to sometimes 5mins, they will become operational again.
Just wanted to "chime" in. I just recieved a Casio keyboard from a customer with this same problem to work on. I initially found 4 corroded solder joints. Repaired them, same problem. Ginocumbe's description leans me towards capacitors. Will let you know what I find or even if I cant figure it out. Though 2 years ago, you probably added your synth to the land fill.
Posted on Nov 27, 2010
  • coral_bay_co Nov 30, 2010
    Update: Done with synth repair. Not completely sure wich thing I did got it working. I took it apart
    down to where the key button contacts are. They are similar to what they use in remote controlls,
    where the black pad is pushed down onto black "painted on" traces to complete the circuit. I used a
    tooth brush to move away some light corrosion around the ribbon cable solder points. Did not seem to
    be enough corrosion to cause the problem. I also pulled up the rubber side of the buttons. At first
    they seem to be glued down then after gently pulling one up I found it was only a tight fitting
    rubber push thourgh foot type of thing. Easily pulled out and replaced, I used a jewlers flat
    screwdriver to push it back in. While the button pad was up I lightly brushed the "painted on" black
    traces with a tooth brush. They also did not seem to be corrded enough to cause any problems. Giving
    up I reassembled and was surprized to find the 8 keys in question worked fine and repeatedly as they
    were supose to. Though the key just left to those 8, that used to work, stoppe working. Well it
    would work randomly, though it always sounded as if I hit the key hard even if I pushed it down
    softly. So I dissasembled it again, this time finding that the painted on black traces has lifted
    off, seemingly due to the lubracant used on the mechanical part of the key weaights. As I do not
    have the bottle of paint on stuff, I attempted to repair by soldering two thin wires to make the
    contact - this was extreamely difficult. Re asembled and the key that was working randomly now works
    great, though the 8 keys from before stopped working. I dont think soldering wires for all 8 keys is
    a good solution, I will tell my customer that I may be able to find a bottle of the paint on stuff
    and can try that to fix them, though my observations make it seem to be another issue causing it.
    This is inconclusive but more info for the next guy to go on.
Casio keyboard ctk 2100 won't turn on
Do you have dead batteries, remove and use the adaptor only - try again.
Oct 21, 2012 | Casio CTK-2100 - 61 Key Portable Keyboard...
Problem with casio CTK-691 keyboard
"can I do it my self or should I go to a professional to get it repaired"?
Get it repaired by a professional. Casio gives long warranty (5 years in Australia). Mine took weeks for Casio Service to repair. Many boards had to be changed.
Jan 25, 2012 | Casio Ctk691 Keyboard
The "keypad" showing the keys
Make sure you're using the right power supply for the keyboard, and check to see that it's plugged in all the way. Alternatively, try using another power outlet.
May 04, 2011 | Casio WK110 Portable Keyboard
I fixed the dead keys on my Casio WK-200 keyboard. Now some...
Most of these have VELOCITY sensing and that involves two contacts per note. If the velocity sense on those notes is somehow not working, broken wire or trace on the board or short that MIGHT cause your problem.
Aug 12, 2009 | Casio Music
The number keys doesn.t work properly: `1 `1 2(f1) 3 54 54 67 67 =8 9 -0 -0 =8.. that should be: ` 1 2 3 4 5 6 7 8 9 0 - =
Sound's like dust is the issues here, so you will need to remove the keys that you are having trouble with or all keys to be on the safe side, once removed get a damp cloth and clean the keyboard where the keys once were and while your doing that soak the keys in some water to clean them up and dry them when done. Put keys back into place and test keys to see if problem as gone or not. Hope this helps.
Jul 17, 2009 | A4tech KBS-720 Anti-RSI Keyboard
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
My casio 496 cannot connect to fruity loops
Unfortunately your model of Casio only has midi in and not midi out. You will be able to use it as an external sound module but not to input notes into Fruity Loops. In other words midi out of your computer to midi in of the Casio with the proper settings will play your Fruity Loops sequences through the Casio.
Jun 18, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Keys on Casio keyboard pulled up
I have a Casio CT-648, which looks like a smaller version of yours. I had the same problem, and got brave and opened it up. I took off the back, which takes several screws. Once it was opened up, I saw the keyboard was fastened to the frame in sections of keys. I unscrewed the section with the raised key (I believe it was 5 screws), slid the key section toward the front of the keyboard, and was able to get the slides to re-engage with the tab below it. I now have a smooth keyboard.
Apr 05, 2009 | Casio Portable Keyboard Touch Sensitive...
Casio WK 1600 : Sustained keys
Remove all power sources for at least 2 minutes. That means removing the batteries and power cord completely from the K board. Then try again. If that doesn't do it, it'll be time for a service visit...accordianman
Sep 18, 2007 | Casio LK30 Note Lighted Keyboard
164 people viewed this question
