Question about HP Compaq dx5150 PC Desktop
Cannot connect to internet, DSL on my HP DX5150
I have 4 other PC's that have no problem on the same network. It comes back that it can't find my network hardware.
  • donalso Nov 30, 2008
    Your the Man!!!!!!!!!!!
    Sergeant:
    Champion:
  • 334 Answers
Thats the driver that it takes to run the network plug on that computer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=447469&prodTypeId=12454&prodSeriesId=457124&swLang=13&taskId=135&swEnvOID=1093#11395
copy and paste that into your address bar. Your network card driver is there there is 4 to choose from but read the names and they will tell you which ones you can eliminate.
If you can you shound peak at your network card to tell what kind it is. I mean just take the sides off and look at the network card and see if you can find a name
God Bless Greg
Posted on Nov 30, 2008
How do i connect a wifi router to the dsl of my pc?
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Sep 23, 2011 | Computers & Internet
Phone Number 847-699-9958 New DSL Internet problem getting it installed on my computer. Error message is, Your computer is not connected to the 3 Wire Gateway. e-mail address is...
You need to connect your computer to the dsl box and the box to the wall as instructed, you may have to change your internet settings a little.
Find the my network places icon on your desktop, right click and select properties
the network connections screen comes up, you can also go to this via the control panel
right click your internet connection select properties
scroll down the list to internet protocol tcp/ ip select it and press on properties
make sure the settings are set to Obrain an ip address automatically and the 2nd page is empty,
click ok
click ok again
try your internet again.
Aug 11, 2008 | Washing Machines
My HP a6200n won't connect to the internet. it says it's connected to and unidentified network. It is a DSL hookup and I also have a wireless router hooked to it the router is pumping out signal which is...
directly connect the dsl modem to your pc and then restart your system. once your up and running the pc should automatically create a connection with the modem device. once you have established an internet connewction this way, shut down the system and reboot. after complete bootup, unplug the power supply cords to both the modem and the router. now plug im the modem, wait 1 minute and plug in the router. after about a minute you should now be able to connect to the internet both by your pc and wireless connections.
Jan 17, 2011 | HP Hewlett Packard Pavilion A6200N PC...
Hp compaq dc5700, internet connection fails and needs constant repair to work, I have all current drivers from HP and windows XP Pro updates, I tried a network card in a PCI slot and had the same problems.
Are you connected to a router? If so, then it is your router that is failing since it could not sustain a network connection with your PC.
Possible causes include defective or failing DSL modem. Lastly, your ISP.
But based on your description, you seemed to be disconnected from network and needs "repair" of the network IP to renew in order to connect to the internet. If that is the case, please check your router first.
Feb 03, 2010 | HP Compaq dc5700 Microtower - Free Flat...
No internet access with wireless
First of all check the DSL cable must be in WAN port of the linksys router. if it is done then do the following.
Actually DSL modem and Linksys router are conflicting with their IP class. Means DSL and Linksys routers are using the same IP class of 192.168.1.1 or 192.168.0.1.
You must change one's IP class because both are routers and if they having same class they cant communicate. Unplug the WAN cable of the linksys. open browser and put ip 192.168.1.1 or 192.168.0.1 any one which works for u in the address bar. Username and password hopefully be admin admin or just admin and password blank field.
when you access the linksys router configuration page then come to LAN configuration. If there IP is 192.168.1.1 then change it to 192.168.0.1 and if it is 192.168.0.1 then change it to 192.168.1.1 Save configuration and reboot your laptop and plug dsl cable to linksys WAN port.
Hope now this will work.
Regards;
Hasan
Dec 30, 2009 | HP Pavilion dv6000z Notebook
I have a used compacq 530 but do not know what is missing because i cannot get it to hook up to the internet
Possibly if you gave more information .....does it have a network card installed, is the network card "enabled" in the hardware settings, does the network card have correct drivers ? ( no yellow question mark beside it ) Do you have an internet provider and account ? Is your internet high speed or dialup, if it is dialup, do you have a modem installed - with correct drivers ? Is it working - do a modem query to see if it responds ?
If using a network card and cable or DSL internet, is the cable connected from the PC to the cable or dsl modem ? Is the cable or dsl modem plugged in and the power and wan light on ? With the little bit of information you have given, it is not really possible to give an exact answer to what the problem is.
Aug 30, 2009 | HP Compaq d530 SFF PC Desktop
How TO connect XBOX360 to Back of computer and be able to use both at the samethime. Have DSL internet
Why connect the XBOX to the computer? Can you connect it to another port on the DSL router or do you only have one port for internet connection? If so get a DSL router that will allow you to connect multiple network devices. The router will have to be configured like the current PC so that it can connect to teh internet. Then you can connect your XBOX to one of the router ports and teh PC to another port. Your PC ethernet internet connect will need to be changed so that it uses DHCP.
a second option:
You PC probably only has one ethernet port that you are using to connect to the DSL. You will need to get a second ethernet card for the PC to connect the XBOX. Not worth the trouble or $$$.
If you
Aug 11, 2009 | Computers & Internet
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
No internet connection
This should be connected as so. From wall outlet to DSL modem, from DSL modem to D-Link router, From D-Link router to Laptop via wireless or wired connection. You will still need the DSL modem installed but the wire coming from the DSL modem will go to uplink port on the router instead of into the laptop.
Dec 21, 2008 | Computers & Internet
WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Jun 01, 2008 | Computers & Internet
HP Compaq dx5150 PC Desktop Logo
137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
