Question about Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer
New frigidaire washer (affinity)
My washer keeps saying err... pau 47 ...how do I get it to start a new cycle? What is wrong with my machine? I did not get a book with it because lowes in Yuma just sold my husband the display off the floor. thank you kimberly
  • Erkle Sep 15, 2008
    I have the same issue but the dial leds do not change or move. do you have a general reset for these?
    President:
  • 878 Answers
Kimberely, The err 47 means that the control board is not sensing the door lock. First try unplugging the machine for 1 minute and see if it comes back to normal. If it doesn't put it into the door lock test, with the door closed, by doing the following: Turn the program knob to drain spin. Press pause cancel to turn off the LEDs. Within 5 seconds, press and hold the option and pause cancel buttons until the LEDs start sequentially chasing, then release the buttons. All the LEDs will sequentially light. Turn the program knob 4 clicks from the start position clockwise, the door lock solenoid will activate. The door should be locked. Turn the knob one more click clockwise and it should unlock. You can toggle back and forth to test it. If the door lock is working and you are still getting this code, then its a control board problem. You should call for factory service. If you have any more questions, you can email me at catriver1@gmail.com Catriver...post back.
Posted on Jan 21, 2007
  • Ron Marek
    Ron Marek Jan 21, 2007
    To exit the test mode, just unplug the washer for 10 seconds.
Frigidaire front loading washer will not start will not stat, I get a PAU or ERR message, tried resetting by unplugging for an hour, removed and cleaned soap dispenser, and checked door for proper closure....
Thank you for your question, Friend.
If you are still receiving an error code PAU after resetting your washer, then the door of your washer is probably not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If the issue persists, then your washer could possibly have a faulty door latch, door strike or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Best - Z
Aug 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Dec 01, 2007 | Frigidaire Affinity ATF7000E Front Load...
Err Err err err err pau
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer Logo
696 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
