Question about HP w1907 LCD Monitor
My monitor say to me osd lockout.. can you help me? please
Hold the MENU button for ten seconds to unlock or lock the OSD.
Posted on Dec 08, 2008
My monitor HPw1907 menu keeps popping up and sometimes scrolls randomly. Along with that the sound keeps diminishing by itself. I am wondering if there is a short in it? Anyone out there wise to what is up with that?
Posted on Jan 24, 2009
    Problem Solver:
  • 5 Answers
Hi I had the same problem but luckily I was able to fix it. If you press the menu button down for 10-15 seconds The OSD lockout scren will go away and you will have access to the regular menu. When I did this I noticed that on the menu screen, all the menuoptions would become highlighted one by one as if I press the " - " button on the monitor. This gave me the conclusion that the button was the culprit. The button was not stuck because I could press it and it would go in and pop back out. So I removed the base plate (3 screws) and then I found that on bottom 2 corners you will see a **** on the black inner plastic (use a flashlight) Stick a flat tip screwdriver there and gently pull the black frame out. Once you do that you will gain access to the panel that hold the 4 buttons. Remove the plug and separate the board with the buttons from the black plastic base by prying the plastic clips back. If your faulty button is the " - " button like mine then gently pry the metal cap thats on the top of each button until you remove it ( If done carefully you can replace it by pressing the metal plate back on) Once you remove the metal plate you can remove the actual button. Look down to locate a thin copper concave circular plate. I used a metal polishing paste to shine the copper concave plate on both sides once shined place it back in the button and put the button inside then press the button downto ensure the button goes down and pops back up. If it doesnt then gently press the middle of the copper plate with the tip of a screwdriver and try it again. If the button goes down and pops back up you can place the metal plate over the button and press down to fit down in place. Reassemble and this will fix your issue. I was so glad I got rid of that annoying OSD lockout white screen once I did this technique. Good luck and post something if it worked for you!
Posted on Apr 06, 2011
4 Suggested Answers
SOURCE: osd lockout
hold the MENU button for ten seconds to unlock or lock the OSD
Posted on Aug 19, 2008
  • 156 Answers
SOURCE: HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Posted on Nov 30, 2009
SOURCE: How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Posted on Jan 20, 2010
Need OSD Lock out removed permently Please
have you tried the following steps:
  • Press and hold the "Power" key on your monitor to turn it on. Press the "Menu" button for 15 to 20 seconds to cancel the OSD lockout message.
  • Press the "Power" button on your monitor for several seconds until you see the OSD lockout message disappear. Unplug and re-plug your monitor power cable back into the outlet if the OSD lockout message is still displayed.
  • Turn your computer's monitor off. Press the "Menu" button for 15 to 20 seconds and power your monitor back on.
  • Read more : http://www.ehow.com/how_10015851_fix-osd-lockouts.html
    Apr 09, 2015 | Microsoft Windows 7 Home Premium 64BIT...
    Monitor display says OSD Lockout /no signal input how to fix this?
    This document pertains to LCD monitors .
    One of the following messages appears on the screen (over the items being displayed).
    OSD Lockout
    OSD Lock-out
    ... or similar message.
    This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
    NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
    To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
    Aug 31, 2013 | Dell Computers & Internet
    How do I remove 'OSD LOCKOUT' from my monitor/screen?
    Try holding the power button or the menu button of the monitor for about 5 - 10 seconds. This should remove the OSD Lockout message. Consult your monitor's reference manual if you still have problems.
    Apr 11, 2011 | Computers & Internet
    Osd lockout
    I hope it helps.
    If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
    All the best.
    Mar 29, 2010 | HP w1907 LCD Monitor
    Osd lockout? How do I get the on screen display unlocked?
    OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
    Dec 03, 2009 | HP W1707 LCD Monitor
    Nov 30, 2009 | HP 2009M Monitor
    How the unlock osd
    OSD Lockout in HP Monitors First restart the Computer. Then hold down the menu button for 30 seconds, the main menu appears, then exist the main menu, then remove power cable of the monitor, then hold down the power on button of the Monitor for 30 seconds, then plug the power cable to the monitor. The OSD Lockout problem set rights.
    Nov 12, 2009 | HP vs15 15"LCD Flat Panel Monitor
    Osd lockout
    If you encounter an OSD Lockout error with your monitor simply try the fixes on this page:
    http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
    Mar 27, 2009 | HP w1907 LCD Monitor
    OSD LOCKOUT
    1. Replaced the Micro switchs.
    2. press the menu switch 15 to 20 secunds.
    Nov 02, 2008 | Computers & Internet
    HP w1907 LCD Monitor Logo
    362 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
