Question about GE Profile Harmony DPGT750EC Electric Dryer
Getting into a ge harmony dryer no heat
Breaking down case
  • clmtboy1904 Dec 12, 2008
    my harmony dryer has no heat. How do i fix it?
    Problem Solver:
The blower motor went out, mine did twice I replaced it and the heat worked. The motor is pretty easy to change.
Posted on Dec 17, 2008
I have a GE profile Harmony gas dryer model #DPGT750GC1PL. the dryer runs but there is no heat or air coming out of the vent. diagnostics do not indicate anything wrong
see this causes and fix it. God bless you
There's no heat dot_lineone.gif 1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 02, 2012 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Harmony DPGT750EC Electric Dryer not heating
inverter board may be bad. how long have you had the machine
May 07, 2010 | GE Profile Harmony DPGT750EC Electric...
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
No Heat!
Possibly a dodgy coil or thermistor/thermostat that only breaks down under heat despite the impedance being fine when cold.
Sep 15, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
post your email i will send you the book there are too many things to check via posting here
Mar 09, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
195 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
