Question about Onkyo Audio Players & Recorders
Onkyo TX-SR876 Screen images freeze after unit is on for an extended period of time. Unit has plenty of ventilation and the issue can only be resolved by turning the unit off and back on again.
jeesusfreek
  • 18 Answers
SOURCE: Onkyo TX-SR500 loosing settings
Turning any receiver off will erase the settings - there is no backup battery (Onkyo uses Battery Free Memory Backup) and the length of time depends on the capacitor charge. Why not just leave the receiver plugged in? Stand-by mode uses a negligible amount of power - enough to keep the capacitors charged and the LED on the front panel on.
Posted on Jan 28, 2008
robotek
  • 1512 Answers
SOURCE: No receiver display lights
Hi ripper
The unit has a built in display dimmer, with a button to control the level of brightness from the display both on the remote, and the front panel.Try this
regards
Graeme
Posted on Mar 21, 2008
SOURCE: Onkyo receiver audio problem
I have Found two problem which cause NO AUDIO 27-07-08
jaiki39@yahoo.com
  1. 1.Failed connection between top &bottom of circuit board NCDG-6575 (Dolby --DTS) processing board.
Near & under IC Q710
2.Failed componet IC Q710 part # LC372100PT
IF you disconnet CKT board NCDG-6575
you will get audio on speaker B left & right CH only
SOLUTION have CKT board NCDG-6575 Repaired or REPLACED
Posted on Jul 28, 2008
dunnbiker
  • 8546 Answers
SOURCE: how can I hook up bose 901's to onkyo tx-sr876
Assuming you really want to have a working surround system you will need a separate stereo amplifier for the 901's to accomodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 110W for mine and it ahs plenty of steam for the 901's.
For connectiuon I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ';s Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
Posted on Apr 13, 2009
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
Sceen on tv freezes
Open the cover and place a fan on top of the HDMI board. most likely this will be the cause since most issues with onkyo are related to heating.
this should do it.or try to reset the HDMI Board, HOLD BD/DVD button and press power bottom it will give you an option to disabe the HDMI card. it that does not work contact me I can give you the steps to run the ONKYO diagnostics it's conbination of keys that will give you about 50 diferents tests to perform.
Nov 27, 2011 | Onkyo TX-SR876 Receiver
Lost power for 30sec audio will not work when power came back on
Reset the amp Press VCR/DVR and them power. once you see CLEAR on the screen. press power
Sep 04, 2011 | Onkyo TX-SR876 Receiver
Unit shuts off and then comes back on might last for 5 min or 2houres
It sounds like your receiver is going into protection mode. This usually and most commonly occurs from excessive heat. If your receiver is enclosed in a tight space with little to no ventilation than that is why you are experiencing this issue. I would suggest you try to get some ventilation and see if that will fix your problem.
Good luck
Jan 06, 2011 | Onkyo TX-SR500 Receiver
Display Panel Problem.... my Onkyo TX-SR805 AV receiver works properly except No Display on the front panel. I follow the instruction troubleshooting on the manual by resetting the unit but to no...
I follow the instruction troubleshooting on the manual by resetting the unit but to no avail. It's beyond warranty period.
please help, thank you
Sep 27, 2010 | Audio Players & Recorders
I have a Onkyo TX-SR806 HDMI output does not work anymore. Tried switching HDMI cables. My component video output works.
Sounds like you may have a bad HDMI card my friend. I had an issue with my HDMI card that was causing blue dots to appear on the dark parts of the screen, when outputting 1080p over HDMI. This is a rather common issue, so it wouldn't surprise me if your HDMI board needs replacement - especially if you've ever experienced the infamous blue dot issue.
Jan 22, 2010 | Onkyo TX-SR806 Receiver
Onkyo TX-DS575 - intermittent audio
You have a problem that was inherent with all Onkyo receivers from this period. You need to contact Onkyo because the microprocessor needs to be replaced. Last I checked, its about $80 from onkyo.
This is NOT an isolated incident as darn near every Onkyo receiver model had this problem.
Good luck...
Rob
Nov 15, 2008 | Onkyo TX-DS575 Receiver
124 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
