Question about Dell 1450 (D1450U) Wireless Adapter
Ethernet is coming up code 10
How do i download in driver if i cant get on the net
You can also use another computer to burn it to a cd. dells website has all the drivers
Posted on Jan 13, 2009
  • Dell Master
  • 12,061 Answers
You need to get a Memory Stick or the like, Then go to another net connected PC, download the driver whatever, copy to the USB Memory Drive, remove take to the computer requiring the driver copy across and install...
Posted on Nov 30, 2008
ETHERNET CONTROLLER CODE 28 FOR WINDOW 7
Windows error code 28 indicates a missing or damaged driver file
you will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled If you are trying to connect through a modem / router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel, administrative tools, computer management, device manager scroll to network adapters should see a yellow question mark? right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc If you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima or you could download one http://download.cnet.com/realtek-rtl-gigabit-and/3000-2112_4-10278840.html http://download.cnet.com/realtek-rtl8139-family-pci/3000-2112_4-91313.html http://download.cnet.com/3dp-net/3000-2112_4-10915115.html If these driver packages aren't right http://download.cnet.com/2000-20_4.html Tick in either the all software or windows software box on the home page you should see a search tab just type in what you are looking for you might have to search/try a few times to get it right IE: Motherboard name Ethernet drivers or lan drivers
Jan 29, 2013 | Microsoft Windows 7 Ultimate for PC
How to intalled broadcom net extreme ethernet contoller
You can download the driver for "Broadcom Ethernet Controller" from the following link: http://download.cnet.com/Network-Broadcom-440x-10-100-Integrated-Controller-Driver-Version-A02/3000-2112_4-176199.html After opening this link, click on 'Download now'. When a pop window appears, click on 'Run'. The driver will install automatically.
Jul 04, 2011 | Microsoft Windows XP Professional PC...
Dell dimension 4600 ethernet port/driver issue
The link for the drivers is ftp://ftp.us.dell.com/network/R67150.EXE
If runningit directly does not install the driver go to Device manager and right click on the ethernet adapter and update the drivers. Use the manual method and browse to c:\dell\drivers\R67150 for the driver location. also the latest .netframweork is downloadable from here.
Aug 07, 2009 | Dell Dimension 4600 PC Desktop
Network adapter
USe The PAckage which you Downloaded From Net.
Open DEvice MAnager By Rgt Clicking the My Computer Select Manage Then Select Device Manager From MAnager from Left...
Your Network Adapter Icon is Overcomed by "?" this sign Rgt click on it Now SDelect Update Drivers. Now It will Ask to go on net Skip This Step. In Next Step Provide the location where your Downloaded Driver is located.. It Will Install.. if Any Error Occurs then Select "Ignore Option If it is there"...
May 14, 2009 | Computers & Internet
Desperately need ethernet driver for xp
Download from following link.These are updated drivers.
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L)/RTL8139C(L)+/RTL8139D(L)/RTL8100(L)/RTL8130/RTL8139B(L)
Thanks
Feb 17, 2009 | Microtek Computers & Internet
Ethernet controller driver&wireless driver for tecra m1 notebook
you install internet explore or install new operating system you chak you lan show ip address
Jan 27, 2009 | Toshiba Tecra M1 PC Laptops
I cant install the ethernet driver on my compaq presario sr1050nx
go to 'support' at www.hp.com and look for dirvers for your model. There should be a driver for the 10/100 tbase ethernet device. Download and install it and reboot. Should fix the problem if the ethernet adapter is working.
Dec 12, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Network card
Yuo need to install a driver for your network card. Go to the IBM WEB site to download a network driver for your particular model ThinkPad.
Nov 12, 2008 | IBM ThinkPad A21m 2628 Notebook
How do I down load ethernet controller, PCI Device, SM Bus Controller, video Controller (VGA Compatible) & other devices driver
if you want to download from the same PC then you cant as the Ethernet driver will not be installed ..
if it is installed then you can download ....
check it in the
control panel>system(switch to classic view in case of XP)> hardware>device manager
in device manager go to network adapters there if the Ethernet driver is installed then you will be displayed there (if the driver is not installed then you will not see that network adapters also)
if it is not installed then you must download the Ethernet driver from some where else to your system from your manufacture(motherboard or chipset manufacture) website (if it is intel then http://downloadcenter.intel.com in this website you can search it & download)
if you have the Ethernet driver installed then you can download from your system only the other drivers from the manufacture website ....
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Jul 04, 2008 | ASUS P5PE-VM Motherboard
Dell 1450 (D1450U) Wireless Adapter Logo
110 people viewed this question
Alun Cox
