Question about GE Profile Harmony DPGT750EC Electric Dryer
Getting into a ge harmony dryer seen some posts on it not heating up cannot get to element to check it model #dpgt750ec1ps
Taking everything out though the front my breaker was bad not getting both legs of my 220 after I put it all back together I trip the high temp thermister and had to take it all back apart to reset it so do not run your element without air over it for to long.
Posted on Dec 01, 2008
My GE profile harmony dryer blows cold air on any setting do I need to replace heating element?
Yup...heating element (usually there are two) is done. Likely the first one was done long ago and the second has finally died.
Dec 03, 2013 | GE Profile Harmony DPGT750EC Electric...
Electric GE harmony dryer runs but will not dry. Do these newer models not have heating elements? if not what has gone wrong with it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 19, 2010 | GE Profile Harmony DPGT750EC Electric...
GE Dryer PBSR353ET5WW.. I believe this unit is manufactured in Canada.. unit works, but does not heat up..
Check and clear the lint filters, and reset the circuit breaker. If your dryer still does not heat up, it is likely that the SWITCH controlling the heating element, OR the HEATING ELEMENT ITSELF is faulty and needs to be replaced.
Jun 07, 2010 | GE Profile Harmony DPGT750EC Electric...
The blower and heat are not working my ge harmony electric dryer
If blower isnt working you wont feel any or very little heat in the drum
Aug 19, 2009 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony dryer error message
Possible Solution...
When you get message first try turning off. Open door spin drum one or two times. Close door. Power back on/start.
Works for our problem. Post if this helps.
Oct 29, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
95 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
