My new monitor turns on then goes blank after a few seconds.
After continuously turning my monitor on and off (this can't be good for it) for about three minutes it will finally show what's on the screen without going dark. If I leave it and the screen saver comes on it will do the same thing. Is this a power issue, hardware issue or possibly software issue?
  • Frank Doll
    Frank Doll May 11, 2010
    Is your monitor a flat screen? CRT monitors somtimes have a power issue when going to sleep and awake etc... Most flat panels don't. Video cards must be seated correctly in their slot and the driver should be updated to the latest one. Just something to try without any info from you.
  • c r
    c r May 11, 2010
    what type pc, operating system? for how long has problem persisted? provide as much info as you can on the hardware. (belarc advisor is good to get hardware info). type belarc advisor into the search box.
  • 64 Answers
It sounds like a power issue OR weak signal. If you use an extension cable on your monitor cable this can couse the problem.
Posted on Dec 01, 2008
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
My monitor goes blank after a few seconds of turning my computer on. I turn off the monitor & turn it back on again and it only stays on for a few seconds thanks
It basically goes to Power Save Mode. Check for the same error in System Setup screen, if the Monitor goes off in System Setup then you better need a replacement. Else you would need to reseat the Video Card(If any) and the Memory Modules. Please keep posting for any further issues / improvements.
Dec 30, 2009 | Dell Computers & Internet
HP 1940 goes blank After 3 Seconds. after turning on this monitor it goes blank if i turn it off then on again it will display the comptuer output again but then turn off after a few seconds. any hints?...
Run a monitor aelf test.... Remove the monitor cable from the back of the tower... and see if it run self test.... also a install the driver for the monitor
Aug 03, 2009 | Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor goes blank after first few seconds of turning it on...
There's an internal electronic part/s of your monitor that are cold soldered / defective. I suggest to bring the unit to an authorized service to properly diagnosed & fix the problem. best regards
May 25, 2009 | Proview PT 15.1" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Blank monitor
Luckily I'm not in it for the money so here's your answer. (Sorry drumbanger.)
When it goes black, look at your power button. Is it still green? If so, the backlight display is bad. If the power light has turned orange, you're most likely looking at a power/inverter problem. Sadly, if you don't have another monitor that you can swap parts out with, you're looking at a new monitor. But with the economy on the downslide, replacements keep getting cheaper! Research online and you'll find some fantastic deals! Rate me if you find this helpful.
Feb 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
262 people viewed this question
Alun Cox
David Payne
David Payne
