Question about Maytag 24 in. MDB6100A Built-in Dishwasher
Flashing LEDs All indiactor lights on the control panel are flashing and no response to the keypad.
  • 4 more comments
  • Linsiler Nov 08, 2007
    Same thing with me. Maytag MDB6100 just started all the lights flashing when the door is closed. So I've kept the door open, til I figure this out. No mention in the manual about this.
  • P583 Dec 12, 2007
    Same problem!
  • kilirose Jan 01, 2008
    Same thing. All lights are flashing, no response to pressing keypad.
  • Kelly707 Jan 13, 2008
    same problem, I was told to unplug the unit and let rest for a few minutes and when you plug it back in it is supposed to reset the electrical. No success with that!
    good luck, I'm still looking for solution!
  • Twalter Jan 26, 2008
    I has the same problem, numerous times. A few times the problem corrected itself after a few days. I've turned the power off with hopes that the unit would reset but that didn't work. I think this is a problem with the keypad which in my experience can cost as much as half the cost of a new dishwasher if not the full price of a new dishwasher Iif you are having a repair to do the job for you).
  • Anonymous Nov 07, 2008
    my problem isn't that all the leds are flashing. it's that the "clean" and "rinse only" leds flash at the same time and the unit doesn't run. I"ve tried shutting off the power at the main breaker as well as the plug to get it to reset, no luck. The drain pan is full of water and won't drain.
    It appears as if there are alot of people with the same type of problems. Any recalls on this?
When doing some floor work, I had taken off the front bottom panel of the dishwasher and there was a pamphlet which had electronic information. Dummy me threw it away, but I remember it had code information on it. I am now having this flashing light problem. So check behind the front bottom panel (remove the 4 screws to get behind it) and the piece of paper should be in there. Please let me know if you find it!
Posted on Jan 06, 2008
I did some searching online and found this simple solution which worked like a charm for me.
After having the power off to your dishwasher, to turn it back on, if the lights are still flashing press the off button. This stopped the flashing lights and I was able to use the dishwasher again.
Posted on Jan 26, 2008
Cf flashes on keypad will do nothing
Posted on Apr 21, 2008
The control panel flashes its lights and chair wont move
When my Pronto did this, it was diagnosed as a failure of the controller. Replacement was about $1200. Good Luck.
Dec 09, 2014 | Health & Beauty
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Light keeps flashing in spa
Sounds like control panel failure or the keypad is locked/stuck.
Try hold temperature UP & DOWN together for 6 seconds.
or if you have a Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
As your lights are flashing the button might be stuck in the down position.
Jul 18, 2012 | Balboa Instruments Pool & Spa
Maytag dishwasher mdb7100aws is flashing clean-lightwash-heated dry
I have a Maytag MDB7100AWS which suddenly started blinking the following LEDs: Clean, Rinse Only, Regular Wash, Tough Scrub and Heated dry. Tried cycling the breaker, no help. Tried the key sequences in the troubleshooting sheet behind the kick panel, no help. Then happened to press the Drain/Off button twice. All LEDs went out and am now on my second successful load, fingers crossed. Suspect the control board got latched up somehow.
Jan 25, 2012 | Maytag Dishwashers
I have a 1998 Plymouth voyager and the climate control lights are flashing. I ran a test i found on the internet and got it down to two lights flashing(the ac and the recirculate). I got it to where the...
OK got your message on the other post (About the van) I am assuming that your Voyager is equipped with Automatic Climate Control. Follow the instructions below and you will get a better idea of what is wrong with your system.
Calibration/Diagnostics
1. To enter calibration/diagnostics test, set parking brake. Start and warm engine to normal operating temperature. With engine idling, turn blower switch to high. Turn mode switch to panel. Open all outlets. Move temperature to full cold.
2. Press and hold rear wash and rear wiper buttons simultaneously for 5 seconds (Until ALL LEDs illuminate). All LEDs should illuminate for 5 seconds. Rear wiper and intermittent rear wiper button LEDs will flash alternately during calibration/diagnostics test.
3. After approximately 60 seconds, if only the rear wiper button LED is flashing, calibration is successful and the system is okay. If rear wiper and intermittent rear wiper button LEDs are flashing, Diagnostic Trouble Codes (DTCs) are present. (See "Reading Diagnostic Codes" below)
4. To exit calibration/diagnostics test at any time, press the rear window defogger button, rear wiper button, or cycle the ignition off and then on. Test will automatically terminate 15 minutes after calibration/diagnostics is entered.
1. Perform calibration/diagnostics test. If a DTC is present after calibration/diagnostics test has been performed, system will flash rear wiper and intermittent rear wiper button LEDs in sequence. Rear wiper represents code level, and intermittent rear wiper button LED represents code value.
2. Each time the rear wash button is depressed, rear wiper button LED wil cycle to the next code level in numeric sequence. After code level 5 is reached, rear wiper button LED will cycle back to code level 1. See table below.
May 12, 2011 | Plymouth Voyager Cars & Trucks
When i turn on the printer all the lights are blinking, i have reset the printer many times, restarted my computer and nothing has worked to help the problem. I just printed yesterday with this printer...
The Epson Stylus Color 880 has 4 LEDs. If all 4 are flashing or blinking then the printer has a maintenance request error. It means that the waste ink counter has reach its limit. The remedy is to replace the waste ink pads and reset the waste ink counter. You can use the SSC service utility to reset the protection counter. You can download the utility from here http://inkjetprinterhelp.us/epsonSSC.html
You can also use the control paler to reset the counter. Timing is the key to success when you reset the counter using the control panel so keep that in mind. To reset the protection counter using the control panel (front panel):
Step 1.Turn the power on while holdint the following buttons doen. Paper feed, cleaning button. (thr paper out light will flash for 3 seconds)
Step 2.While the paper out light is still flashing press the cleaning button for 10 seconds. The following leds will flash in sequence Ink out lights black and color, Paper out light. Once the printer starts to initilize the counter should be reset. This will reset the protection counter.
Feb 17, 2011 | Epson Stylus 880 InkJet Color Printer
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Sony PVW-2600 Flashing lights on control panel
If this control panel has the hard brown plastic LED holders, that could be the problem. They can absorb moisture from the atmosphere, corrode the LED leads, and deposit a conductive goop (that's a technical term) on the PCB, screwing up the lamp logic. Replace all the holders- Sony only sells a new, improved version- and any LEDs with corroded leads. Clean the PCB thoroughly with alcohol to get rid of all the goop, and you should be fine.
Aug 08, 2008 | Sony PVW-2600 VCR
Nuvo NV-4A Keypad Flashing/Won't Work
I have the same problem. All keypads blinking in All Off. I changed the fuses on the Nuvo. No luck. Does anyone have a solution to this?
Jul 12, 2008 | Nuvo Simplese D 4-Source 4-Zone Audio...
Maytag 24 in. MDB6100A Built-in Dishwasher Logo
629 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
