Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Many late model cars built since the early 90's both foriegn and domestic models have gear reduction starters that are copies of or made by Nippon Denso electric of Japan, when the starter just clicks or clunks then the starter solenoids heavy electrical contacts are burned and the solenoid must be replaced.
Just refer its user manual for details if any. If not, there is no other way than contacting the authorized service center for Nippon, or any experienced service technician. Gopakumar Gopalan Google
If you removed it from the van,why would you think that it was not the right one? Likely Mazda does not make their own computers and that Mitsubishi makes them under contract. It is also possible that there could be several different vendors making the computers for Mazda as several on Ebay appear to be made by Nippon Denso.
Try to download the user manual to your tV fro net. It sounds that the TV is locked for other channels by improper key pressings. User manual will have details about how to unlock it. Search for it in net, with its exact model number at its back cover.
Hello
Your TVs vertical output Ic may be damaged. You just open your TV and locate the vertical section inside, usually panasonic uses Ic numbered [LA7837] which will be marked as part number IC451 on the circuit board. It is a 13 pin Ic, sometimes the number may be different in your TV, as Panasonic uses four types of LA series Ics in their sets. I think that you have some knowledge in the service field, so the complaint states only "loss of vertical sweep", and so I'm not going too deep into description. OK.
toyota batteries are made by nippon denso, a division of toyota car ltd(japan). exide do a pretty good job as do a lot of names, that im sure you remember.cheap batteries have very thin plates/coatings,so last about 2years compared to 5 years plus.
this is a pin-amp section problum .
if your tech. pls check sum spare in Pin -amp section .
pin-amp ic / capaciter / pre-set .
( i think your tv set screen is low width and up or down corner is bend ) if yes then replace capaciter 10uf/63v non poler or Pin IC
