Question about HP Officejet 5610 All-In-One InkJet Printer
How to replace ink cartridges
I have purchased new catrriges for my printer but I have misplacedd the intuction manual and I can't install the cartridges.
    Sergeant:
  • 291 Answers
Keep the printer ON then on the right side there is flap like door just lift that door.the cartridge will automatically come towars the position where it can removed.just pull the cartridge towards your side slowly.and in the same procedure reinsert the new cartridges.
Posted on Nov 29, 2008
I tried to install non-genuine ink cartridges into my Canon MG5150 and now it wont work. It comes up with "B200 printer error unplug and contact service centre" How can i get it working again?
I am sorry to hear that you are having problems with this ink cartridge.
There may be several reasons for the problem.
Lets start out by installing the old ink cartridge if you have it. If you have the old cartidge and reinstall it and don't get the error than I would suggest purchasing another replacment cartridge. IF you still get the error with the old ink cartridge than you will need to send your printer off for service. ( i suggest purchasing a new printer before paying for service.)
Also most of the printer companies have install RFID chips in ink cartridges, So unless its a factory ink cartridge it may note actually work in your printer.
Canon, Lexmark, and HP all use RFID ( radio frequency identification) This prevents you from purchasing cheaper cartridges so you are left with either refilling you old cartridges or purchasing OE ( original Equipment).
I hope this helps you with your problem, feel fee to let me know if there is more I can do for you.
Oct 16, 2013 | Office Equipment & Supplies
New ink cartridge in printer saying empty
Assuming you have a refilled or remanufactured cartridge there this is actually pretty normal. These cartridges have no means of checking for new ink in the cartridge so will continue to warn of empty. They will not however stop you from printing as a result.
If however you purchased the cartridge as a brand new cartridge, you may have been miss-sold the cartridge. In which case I would advise speaking to whoever it was purchased from.
Nov 20, 2012 | HP Photosmart C3180 All-In-One InkJet...
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
924 says that black ink cartridge not installed
Hmmm....that sounds to be an issue with the ink cartridges...
You might be using ink cartridges purchased other than Dell or Staples...since these are the two who sell Dell Ink.
If thats not true, then take out both the cartridges in the printer.
Lets isolate the issue
1. Try only Black cartridge on Color slot(right). If you get Install both ink cartridges error, then its an issue with the Black ink cartridges and if you get message that install Black ink cartridge then its an issue with the prrinter.
2. Now install only color cartridge on Black cartridges slot(left), If you get color cartridge missing then its an issue with the Black cartridges which you are using and if you get install both ink cartridges then its an issue with the black slot on printer.
3. If issue found to be with Black ink cartridge then wipe the Nozzles(bottom) of the ink cartridge with lint free cotton cloth from back to front 5-6 times.
4. Also try replacing the ink cartridges purchased only from Dell or from Staples. Purchased from somewhere else or refilled might not work.
5. If issue found to be with printer, then i would suggest you to purchase new printer then.
Hope this fix the issue
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
Installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Apr 04, 2008 | Canon PIXMA iP1600 Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
