Question about Sharper Image TI150 Iron
I can't figure out how to attach the accessories
The instructions say to slide it on...but that doesn't work. Do they snap on...I'm afraid I'm going to break them. Do you first remove the part that the iron comes with?
Thanks,
vicki
Pray, this was the clencher! No, you do not remove the piece already attached. The attachments to snap on but it takes help from above. Truly.
Posted on Nov 30, 2008
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
How to remove cord on Rowenta DZ2061
Your iron probably has tamper proof outer screws with a center pin...don't be intimidated. First, try to remove the screws with a tiny screwdriver from an eyeglass repair kit. If that doesn't work, get a Torx T-20 nutdriver attachment.
If you have to replace the cord, here's a possible supplier: Smallappliance.com
Oct 05, 2012 | Rowenta DZ2010 Iron
How to clean inside of iron
Please don't take Landsend advice, as it contadicts this whole "fixya" site! Let's keep it going by not giving in to this throw away world! Some people can't afford a $20 iron @ Wally's!
All the solutions above (besides Landsend) are on it!! Your City water is still too, hard for these delicate, devices. Filtered, as Alan Serna mentioned, is the way to go!! Dump your water out of your iron, when not using-maintenance is key, for everything, even your families!! : ) Have a G8 day!
Sep 28, 2012 | Sunbeam 3017 Iron with Auto Shutoff
Where do you put the water in?
Remove the tank by pressing the button on the front and slide it out. Remove the little filter either rotating to the right or left and lift it. Fill with water to the mark and slide the tank back until it snaps in place. Good luck
Aug 17, 2011 | Kenmore KSR500 Iron
F2000 iron won't heat up
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Apr 10, 2009 | Black & Decker D2030 Iron
Rowenta dis assembly pix
I have submittted the photos to one of the expert gurus on fixya and I cannot remember his name. If I remember correctly it is not a screw but a plastic pin (3) that sticks up fom the plate and is secured by a circular disc with fingers in the center that push up when they slide it on and one must open these fingers up, unuslly one will do so it will release. If you try to force it off it will/may snap off the pin. If some one can help you, you might want to get two of those $1.00 screwdriver kits and have one person, or a vise, hold the iron and the two of you slide the small flat screwdrives under the fingers and pry up together, if you can get to it. Remember the one I had was glued together with minimal screws throughout.I have never seen an appliance so difficult to access for the simplest repair. Good luck and God Bless.
Jan 05, 2009 | Irons
Re Conair garment steamer ctx12c
I bought this model from Costco and followed the instructions and tried using the picture on the box. You may have trouble, or at least be confused, if you try to attach like the picture on the package because the hose in the box is not exactly as pictured.  The hose you get does not have that extra ribbed part around the end that attaches to the console.  Therefore try the other end and you should be able to attach.  Once you figure that out make sure you "lock" the hose into place.  If not steam will escape from the loose installation and may scald you if you reach down.
Oct 06, 2008 | Conair Compact Garment Steamer Iron
Parts
Call 800-711-6617 to get a new Hose Base for $3.00. I just ordered three of them and with shipping it was around $17.00. They didn't give me the part number.
Jul 05, 2008 | Steam Fast SF-450 Iron
Instructions for use DiLonghi StiroMeglio compact iron (steam boiler Iron)
Is a long story but i make short.Don`t be afraid to leave your iron on.Is common to water tank iron to get working in more then 5-10 minutes.That machine are really safe since they do have more then 1 thermostat to control the water pressure.
How they work is pretty easy.The boil the water to a certan temperature and you know after certan F. the water become steam generatin pressure and steam.The thermostat control the heater and the electroswitch release the steam
If your in not making any steam after 5-10 minutes make sure you hear the electroswitch working.Sometimes they get cloght and even if the boil is under the pressure you can not get any steam at all
Good Luck
Jun 10, 2008 | Irons
Sharper Image TI150 Iron Logo
100 people viewed this question
Top Sharper Image Irons Experts
Marvin
Marvin
Are you a Sharper Image Iron Expert? Answer questions, earn points and help others
