Question about Dryers
How do I remove the blower wheel on a Kenmore gas dryer #11087692110
    Sergeant:
    Champion:
  • 291 Answers
Take the back off and the 4 screws on the lint chute assy and the 2 screws where the filter is and the assy comes off and you can see the blower wheel but you have to hold the motor shift and the twist off blower ,,,, turn counter clock wise / larry
Posted on Nov 30, 2008
A PEN WENT DOWN THE LINT TRAP AND NOW THE DRYER WONT TURN ON. KENMORE GAS DRYER
can you move the drum by hand?if not the pen is jammed in the blower wheel stopping the motor from turning,if the filter is on top you'll need to remove the filter,take out the 2 screws in front of the filter now make sure the dryer is on a flex line so you can pull it forward to remove the lint filter and then remove the back panel,now you need to remove the 4 screws holding the duct on that the filter slides into and remove the pen and any lint that's in the duct,if the filter is inside remove the bottom panel,remove the filter and take off the duct and clean it out,next time send model number
Feb 15, 2010 | Kenmore 73952 Gas Dryer
Kenmore Elite Sensor Smart Gas Dryer - no hot air
unplug the dryer,if you haven't cleaned out the dryer check the thermal fuse located on top of the blower wheel housing,remove bottom panel,then remove lint filter,now remove the duct that the lint filter slides down into,now you'll be able to check the thermal fuse located on the top right side of the blower wheel housing,there's also a thermister there too,the fuse is the one on the left,part number 3392519 or 3390719,remove one of the wires and read it out with your meter.also while your in there vac out the inside of dryer,if you have a shop vac put it on blow and blow off all the lint that's built up on the motor and you can also blow the lint that's in the back of dryer forwards so you won't have to pull the drum,if you have a long run on the vent line from the wall to the outside blow it out with a leaf blower,if there is any blocks in the vent line,the duct or lint inside the dryer you could have a fire so this should be done every year,now if the fuse is good you gonna have to read out the ignitor,the sensor and the gas coils,if you have parcial heat it's definetly the gas coils,when they heat up they stop working when they're bad,if you need anything else let me know,so check the thermal fuse first,then the ignitor,sensor and coils,if they are good check to see if power is coming down to fuse and ignitor,you have a computer board on this dryer but most of the time it's the fuse and a dryer clean out
Dec 16, 2009 | Kenmore Elite HE4 Electric Dryer
Trying to access the blower fan on a Kenmore 80
Remove the rear panel.
Then remove the screws that secure the blower fan vent on the left side to access the blower wheel.
Mar 08, 2009 | Whirlpool LER4634J Electric Dryer
Remove blower wheel
Put a good fittting wrench on the blower nut and hit it with an impact wrench(left handed threads righty lucy). OR do it the tried and true redneck way get a friend to hold a pipe wrench on the pulley inside the dryer, around the back slide a small hammer handle or piece of wood in between two blower blades at 3 o'clock position and slam downwards to pop that mutha loose. The threads are left handed(backwards). That blower does not wanna go easy.
Feb 17, 2009 | Kenmore 63942 Dryer
Noisy dryer Kenmore Elite 70892 (gas-LP)..
OK, Kenmore,.... I don't work on many of them, but,....
Disconnect power. You have to lift the top to gain access to the screws near the top which hold the front panel to the sides. If it has a top lint filter, you will most likely have to remove the screws holding that to the top, then use a putty knife to release the spring clips at the top of the front panel. Sounds like the blower wheel is spinning freely on the motor shaft, requiring replacement of blower wheel.
Sep 06, 2008 | Dryers
Kenmore dryer help?
Sounds like motor is stalled. Remove the lint filter, look inside down toward the bottom left corner at the blower wheel. Something may be jammed in the blower wheel. If difficult to see, TURN OFF POWER TO MACHINE, remove bottom access panel. 2 to 3 screws on bottom of panel. Remove lint housing (3 to 4 screws) and inspect blower wheel for debris.
May 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 110.76732500 problem
I would take a hammer and hit it hard break it off I have done this a hundred times at my shop then you can put new blade on with ease
Apr 02, 2008 | Kenmore 75944 Gas Dryer
Cold air
J, by the sound of your post, I believe we can rule out the ignitor and thermal fuse because you are getting some heat. You need to remove the lower panel on this dott dryer and get into the blower wheel. There are two clips to push in on the lower panel, it will pull off. Remove the vent screen and the blower wheel housing will come off by removing the quarter inch screws securing it. Once that's off see if the wheel is rubbing against the shroud or has a build up of crap in it. You can run the dryer with these parts off to check the operation. Next you want to check your primary and secondary coils on the gas valve. This is not hard either. Two screws and they are off and on. Sounds like they are not holding and you are just heating for a few seconds. Make sure the vent to the outside is clear so you are not shutting down the gas on the high limit cut out. Look at the attached pics. Number 13 and 14 are the coils I mentioned. On the other pic number 4 is the blower wheel. By your post, sounds like it could be loose or something is in there. Check these things first, then post back. See if we are going in the right direction...Catriver.
Apr 30, 2007 | Kenmore 72062 Gas Dryer
An Old Gas Kenmore 7870701
Michael, here are a few things to check. Can you turn the drum by hand? If not you may have something in the blower wheel binding the motor. You can acess the blower by removing the back panel and removing the two screws under the vent screen on top. Once the back panel is removed the blower wheel will be behind the vent. Three or four screws and it's off. If the blower wheel is ok, it may be the motor itself going bad. Have someone hold the door switch down and while pressing start, give the drum a turn. If it starts running, it's probably a bad motor. Other things to look for is bad rollers. If they are bound up it may prevent the dryer from starting. Check these things out first...Catriver..post back.
Jan 03, 2007 | Kenmore 72602 Gas Dryer
Dryers Logo
106 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
