Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Extremely hot panel between freezer and refrig sections
The outside front edge of the panel that is approx 2 inches wide is very hot to the touch. The panel light inside the freezer section with the ice maker on/off switch is blinking red. Even when turned off this edge continues hot to the touch. Is a fire danger immenent? What is the cause.
  • Jitesh Patel Aug 27, 2013
    I am having the same exact problem. Were you able to get this resolved. If so, what was the issue?
  • 33 Answers
Usually is not a fire danger however there is a problem that needs attention. I would recommend that you call a qualified service man for this one as soon as possible.
Posted on Nov 30, 2008
How to replace front driver door hinge check strap
a lot of door check straps only use a rolled spring pin. If this is broken and you can remove the door trim it will be fixable mostly.
Jan 13, 2013 | 2001 Peugeot 206 1.6
Front edge of fridge cabinet gets exceedingly hot...too hot to touch!
condensor coil is clogged up, or condensor fan is not running.
Dec 04, 2012 | Refrigerators
The front panel between the refrig and freezer doors is getting too hot to touch Would tht be a defrost timer or thermostat?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jun 09, 2011 | Refrigerators
The strip between the freezer and refrig door is extremely hot. Never felt hot before. It is not the door, but the refrig and freezer itself. The refrig is still cold and freezer is frozen.
The heat you are feeling is normal, I wouldn't worry too much about it. If you start having a problem with cooling you may want to look into getting a repair guy to look at it but many refrigerators will heat up in that strip between the fridge and freezer.
Dec 12, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
My Whirpool frig is almost too hot to touch on the outside of the side of the freezer. About an 8 inch strip on front edge. Any suggestions?
When the refrigerator is on, check at the bottom of the fridge to see if there is any air blowing out. If not, your condenser fan is not working and this will cause the condenser to be very hot and transfer heat around the outside of the freezer door. If the fan is working, try cleaning the coils. Although my guess is the condenser is running hot for some reason.
Jul 04, 2009 | Refrigerators
Freezer has been warmer than normal lately
check the door beeding which make seal between the body and door.Clean with mild cold water and check it is sealing properly while it is closed.check the compresor ,it should be light warm not hot.
Jun 03, 2009 | Refrigerators
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Panel between fridge and freezer extremely hot
this is happening because company used pipes inside refrigerator body, as you mentioned now its heating more than normal,. need some technician to check if there any blockage etc. otherwise less heating of body is normal.
Nov 30, 2017 | Kenmore 44103 Side by Side Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
254 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
