Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Does not hold memory of programmed options
When i shut off my jukebox all the programmed options,time/date/credits,ect. are not there when i power it back on. i beleive the battery that hold memory in ram is dead. where is the battery located and how do i change it?
thank you
    Scholar:
  • 195 Answers
I do not know what type of jukebox you have but the the battery will be in the Central Control Computer, this is the case with the Rowe Ami version of your jukebox. It is a 3 volt lithium (disk type) battery.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
I have a 1962 Wurlitzer 1015 which has a Selection and Credit computer for coins credits. There was this Auto mode which used to be able to use but now, the jukebox can only operate one disc at a time. ...
It would not be 1962 as CDs weren't invented.
Continuous play is achieved by flipping the Continuous Play switch on the right of the computer. Or using the Option button on the remote control. One or the other plugs into GREEN plug on the left side of the computer. If the plug is off it won't work.
Jan 10, 2014 | Wurlitzer Jukebox 1015 One More Time...
Hp laptop has blinking red square above touch pad, comp. won't allow for reboot or restoring to factory conditions
If you do an illegal shut down which is power off by holding down the power switch for 8 seconds. The HP computer will then boot with the scandisk program, which will restore your hdd to perfection. Windows XP or later now use 'system restore' to rearrange registry from a previous calender date that the computer used to work perfectly.
Feb 09, 2012 | HP Pavilion dv2911us PC Notebook
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
OMT Jukebox plays tracks continuously but will play selected track when ordered. Have turned off continous play button but it continues to play. Have programmed it not to play but it continues to play.
Perhaps someone has programmed the machine for "Play stimulator" (random play) or background music. The easiest way clear all f is to default the machine to factory settings. First, unplug the memory plug (red wire at bottom right side of selection and computer and turn off power to the machine for 10 minutes with the memory plug unplugged. After turning on power, the carousel will rotate to determine its capacity. After that the machine is ready for operation. Re-connect the memory plug. If you need further help you can contact me, tech@wurlitzer-ohio.com
Jan 20, 2011 | Wurlitzer Jukebox 1015 One More Time...
My lap top beeps and will not recoognise the keypad buttons
You may have a bad memory stick or your os may need to be reinstalled.
Try removing battery, press and hold power button for 5 seconds and then put back in and turn on and see if it works then.
Nov 12, 2009 | Toshiba Portege 4010 Notebook
My 80gb playstation stops as the oppening screen starts up. It will hold at this screen. Sound and picture is on and then it won't shut down with out holding the on/off button for 10sec. Why won't it start...
could be an up date problem need to delete it by
turn on the ps3 so its on the red light then hold down the eject botton and power at the same time
the ps3 should come on then go off
repeate agen and it should come up on the screen with options ( this is maintence mode)
reset system if that dont work reset the other options
may not work if ur usin hdmi cable may need normaly cable
and can delete game saves ect
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
My 1015 Will not accept new entries
Is it in credit? Neither will work if it is not set to freeplay.
Jul 15, 2008 | Wurlitzer Jukebox 1015 One More Time...
Jukebox wil not play . . . all relays buzz when unit is powered up. Might be a bad power supply???
Is this a Wurlitzer One More Time you are talking about? There are no relays. Well there are, but they are in the credit computer. Is that what you mean?
Dave .
Jun 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
How do I adjust the amout of time the battery on the computer can be used, before shutting down?
Goto control panel then power management.You will see options so your pc can hibernate,stand by,ect ect.
Feb 23, 2008 | Computers & Internet
HDD & DVD PLAYER/RECORDER / time date
Is there an option To Save Settings, after setting the time-date ?
Most devices usually have a small internal battery or memory chip that stores this information. however there are also devices that when power is removed completely. i.e a power failure or switched off at the mains, time and date settings have to be reset.
Hope this solves your problem.
Mike @ Compurepair.
Feb 22, 2008 | Televison & Video
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
310 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
