Question about Kodak EasyShare CX7300 Digital Camera
LEXAR 4GB SD MEMORY CARD FORMAT??
I bought a new SD card for more memory. The problem is
the card will not format. It keeps giving the message that the
memory card requires formatting and I hit continue. Then it's
shows the time capsule & says it's formatting for a few seconds.
Finally it goes back to Memory Card requires formatting. ?????
  • 4 more comments
  • michaelsp676 Dec 20, 2008
    bought a new duracell SD 4gb memory card for my kodak easyshare cx7300. it says i need to format the card, so i try and it keeps bringing me back to the message asking me for format it. Help?
  • Anonymous Dec 20, 2008
    i have a kingston 4gb and it is doing the same thing. anyone know what it is supposed to be formated in? FAT, NTFS ect...
  • palmervw Jan 29, 2009
    I have the same issue with three of my SD chips. I expect that it's a microsoft issue. If anyone has solved - please share.
  • aglines Feb 15, 2009
    Same problem, but with a 2G Lexar Micro-SD Adapter and a Kodak EasyShare C913.
  • Anonymous Feb 26, 2009
    I have the same problem with my Kodak EasyShare Z700 and a SanDisk 4GB memory card. Would be delighted to find a solution to this problem.
  • Anonymous Apr 27, 2009
    I have kingston 4g, it work on computer properly and I can format it with NTFS, FAT and FAT32, but none of them can be recognized by by my Z740 camera
    Genius:
  • 1,234 Answers
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
Memory Error Message
There is a white switch on the side of those sticks, and make sure it is not in write protected mode. If that doesn't work, I am sorry to say that stick might of went bad. Before giving up I would take to a professional film place and have them take a look to see if they can get them off w/o formatting.
Nov 21, 2009 | Lexar Professional High-Speed 2GB Secure...
I have a NV10, it will not format the lexar 4GB SDHC memory card I bought, all it says is format error
The NV10 will not accept SDHC type memory cards. The largest card you will find it takes is a 2GB card of the SD type (not SDHC). The camera is not SDHC compliant, unfortunately. If you can return the 4GB Lexar, swap it for a 2GB of the non-SDHC variety. If this answers your question fully, please rate the solution accordingly. Thanks
Nov 07, 2009 | Samsung NV10 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
Memory card full but its new!!!!
Format the card in the camera to initialize it.
Oct 14, 2009 | Samsung NV3 Digital Camera
My memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
May 28, 2009 | Lexar Professional High-Speed 2GB Secure...
Motorola SLVR won't format my memory card.
I am not sure this will work, just a suggestion
Try inserting the micro sd card in the larger sd adapter that will allow you to put it into your computer reader. Try formatting it there instead
Apr 14, 2009 | Motorola Mobility SLVR L7 Cellular Phone
My computer is not recognizing the new Lexar SD 4GB memory card I just bought for my camera. My laptop is not that old, but when I go to the F drive it doesn't recognize that anything is there.
Have you already formatted the memory card? you may do this via the console of your camera. Sometimes you have to format it first before taking pictures as the computer will not recognize it. Please try a USB flash reader as well. by the way another symptom is that your Memcard is configured for 2.0 if your port on your computer is for 1.0 it might not be backward compatible. This happened to me on a Canon but it might be the case with yours as well. Please try to see if it will be read on another computer.
If you need further assistance please do message me.
Sep 07, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Kodak EasyShare CX7300 Digital Camera Logo
1,019 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
