Question about Fuji FinePix A120 Digital Camera
My Finpix A120 c'ant take pictures any more...
My Camera was Workin Fine Until I Pluged it in to the computer Then the Screen Said USB and DSC.And I D'ont know what to do Then it Started Working Again Then when I plugged it in to the computer again it said the same thing.
It's supposed to say that. When you plug it in, it says that, then once you are done uploading the photos and you eject the USB chord, those words will go away and you just turn off your camera and then turn it back on to take more photos.
Posted on Nov 22, 2007
SOURCE:
Pictures on memory card not showing up on camera (DSC-T70)
You most likely did not safely remove the card from your computer and corrupted the cards MFT. You will need to format the card in the computer. It should work after that.
Jan 30, 2013 | Sony 4GB Memory Stick PRO Duo Memory Card
I lost the software to my sony DSC-H1 camera and don't ant to purchase another disk?
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 27, 2012 | Sony Cameras
I plug the camera into the usb port my computer bings but i cannot load picturs ti the computer. I used rthe finpix loading disc but nothing will go to my compuert
You will need to check your manual for download instructions not all cameras are the same however, if you have the camera software installed try following this work flow.
First make sure your camera has enough power to complete the download, turn off the camera plug the USB cable into the USB port on the computer then the mini USB on the camera. If you have been turning the camera on this may be part of the problem a lot of cameras use the playback button to transfer pictures from the camera to the computer.
Diagram of play back button
Mar 04, 2011 | Fuji FinePix A850 Digital Camera
How do i upload pictures from my fiji hs10 to computer? i have loaded software and connected camera via usb port! This does not seem to work, computer doesn't seem to recognise the camera?
Okay I haven't looked into the owners manual on this camera but a lot of downloads from camera to computer require a specific work flow. Most common is to have the camera off while plugging in the USB cable to computer and camera. Then tri3mast_246.jpg for a long second and the camera starts up in a transfer mode to the FinPix software or viewer.
A go around to all this is to purchase a memory card reader which the computer looks at as an external Hard Drive
Feb 21, 2011 | FUJIFILM FinePix HS10 / HS11 Digital...
My finpix F700 camera want let me take pictures
This post is 10 months old I hope you have solved the problem, if not what I first expect is the memory card is full and the camera has defaulted to internal memory and it is also full. I would suggest downloading your pictures to the computer
Mar 13, 2010 | Fuji FinePix F700 Digital Camera
Cybershot wont connect to the usb
are you connecting to the same USB slot you use to connect before?
Check from the BIOS of your computer is USB port is enabled.
or go to My computer then right click, choose Properties, then select Hardware > Device Manager. Look for the Universal Serials Bus Controllers, then expand. Find the usb port right click on it> select disable.
Aug 21, 2009 | Sony Cyber-shot DSC-T100 Digital Camera
My DSC-T1 Camera only takes barely visible pictures
Its problem of ccd imager in your DSC-T1 camera and that part will be replaced.
Sony announced free of cost repair for subject problem. Click Sony CCD Support for details.
Oct 01, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony cyber shot DSC-W1 Digital Camera
I found an online manual for your camera. Page 84 talks about the USB Mode Normal with the 4 dots underneath. It also show a troubleshooting area for this and it is on page 96. Hopefully this will get your camera working right again. Here is the link to the pdf manual. http://www.docs.sony.com/release/DSCW1.pdf
Aug 25, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Black Screen With Green Strip That Says DSC And The And USB Symbole And The Word USB
Try looking at http://www.fujifilm.ca/x3719.xml for firmware or software updates as well as new drivers for your camera. If you are using an upgraded XD card try putting the original back in.
Then follow the directions for doing the updates to use your new card. If all else fails time for a new camera.
Good luck and have a great summer.
Jan 27, 2007 | Fuji FinePix A120 Digital Camera
Fuji FinePix A120 Digital Camera Logo
35 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
