Question about Cnet CNIG914 Router (NWCNIG914)
CNet Router fails to see LAN connection
The CNet CNIG-914 was working well with the cable modem connected to the WAN port and my three computers connected through an Asante ethernet hub to one of the LAN ports. I disconnected the LAN cable and suddenly the router won't recognize the LAN connection any more (light stays off, no activity). I've checked the cable -no problems there. I've connected the router to the modem through the hub on the WAN side -no problem. I've reset the router -no joy. Any suggestions?
5 Suggested Answers
  • 8 Answers
SOURCE: cnet broadband cnig-914
Can you log into the Hub at the IP http://192.168.1.1/ when it is connected to the computer and the internet connection? Perhaps it is just a configuration issue. http://www.cnetusa.com/support/manuals/CNIG-914D.pdf is the link to the manual to setup your router. Without further information about your network and its configuration I can't give more specific information. If you will please post any specifics about your configuration I can hopefully assist further. Please tell me how many computers there are, how many are directly connected to the router and how many are wirelessly trying to connect. Another suggestion is check your boot up order. Often times you have to unplug everything, then plug in the internet router, give it time to full boot up and have all lights on, then plug in the additional router (in this case I am assuming that it would be the CNet Cnig914), again allowing all the lights to come on, then plug in or turn on any pc that is connected directly to the router, followed by any computer that is wireless. This allows each system to be assigned the IP address and recognize the previous equipment. Once it gets an IP and everything is working you shouldn't have to repeat this process.
Posted on Nov 09, 2006
  • 556 Answers
SOURCE: why its working with some ISP's and does not work with other ISP
ISP's have different requirements for connecting a router to their hardware. One required me to enter a static IP address, another requires acceptance of a dymanic IP address and a third uses dynamic IP addresses and requires a PPPoE logon from the router and a configuration change to their modem to switch it to a bridge, and a fourth I have read about require a reboot of their modem device to recognise changes in the MAC address (assigned to the network adapter) of the attached device (router). I am sure these are not all the variations possible, Requirements for router connections specifically the WAN side of the router are specific to your ISP. Often in their help or support areas they either have FAQ's or help pages to explain the requirements or an online technician available through chat who can tell you what is required. Often however it is up to you to be able to perform then necessary configuration tasks (especially on you hardware) to make this happen. I may be able to provide assistance of you identify you internet provider including local provider companies and geographic location (city / State) in some cases to determine their policies and requirements for attaching routers to their equipment.
Posted on Dec 08, 2007
  • 109 Answers
SOURCE: my Cnet CNIG-914 router doesn't give internet connection
There are several possible problems. Do you receive an IP address from the router? To find out, open the command prompt (Start > Run, type in command , and at the prompt enter (without quotes) "ipconfig".
If you have an IP address, try unplugging the router and your modem for 2 minutes. Power on the modem first, and wait for alll lights to stop their startup flashing and testing pattern (1-2 minutes is usually good), then plug the router in.
If you do not recieve an IP address (if your IP address is 169.x.x.x that is most likely the case) then the router is not giving you one. reset it to factory defaults, and follow the instructions to set it up again.
Try those and let us know how it works out for you.
Posted on Feb 06, 2010
  • 137 Answers
SOURCE: how to setup
Plug your DSL cable in your router's WAN or DSL port and then you power ON your router.
Posted on Apr 04, 2010
Unable to connect to internet despite connection confirmed
Improve the FixYa experience for everyone by voting.
I'm going to provide you with some generic approaches in an attempt to solve your problem.
First: Microsoft will perform a complete systems check for you in three clicks with their FixIt app. CLICK HERE and Microsoft will fix (repair) any Windows related problems that might be causing your problem.
Second: It is important to connect the modem to the router before you configure the modem in order to verify communication between them. If the cabling is incorrect, the rest of the process fails.
As a rule, external modems are built with a female data communications equipment (DCE) DB-25 port for connection to a controlling device such as a PC or a router
Connecting the modem using the network cable to the wrong port of the router (other than the WAN port) is easy to identify. You can easily troubleshoot the problem. In some cases, you may correctly setup the wireless router connection but you use the wrong cable type in connecting the modem to the router. Cross type UTP cable must be used in connecting the Ethernet port of the modem to the WAN port of the router. But this is not always true. Today, many types of wireless routers (and any LAN Switches) embedded their Ethernet ports (either WAN or LAN ports) with Auto-sensing type port (auto-MDIX LAN). It means that you can use either cross-type or straight-through-type network cable for the Ethernet port connections. The system will detect the cable type and automatically adjust the ports signal accordingly.
Apr 28, 2012 | Sony Vaio VGN CR353 Laptop Universal AC...
How do i connect a wifi router to the dsl of my pc?
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Sep 23, 2011 | Computers & Internet
Im trying to connect my modam could you please help
First step is to make sure if the modem is functional. This can be done by connecting your computer to modem and check if you are able to log on to internet.
Second step is to connect the cable which previously connected to computer to Router's WAN port not LAN
Third step is to power cycle the modem and router that is power off and on both modem and router
Last step is connect router to your computer with new ethernet cable using one of the LAN ports of the router. There are usually three or four LAN ports on Router!
Good luck! Repost if you still need help!
Sep 06, 2011 | Computers & Internet
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
How to setupmy router Cnet CNIG-914 for PLDT myDSL ISP
Apr 04, 2010 | Cnet CNIG914 Router (NWCNIG914)
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
LinkSys router early deaths
Your cable modem has a ip address of 192.168.1.1 and your router probably has the same ip address. Hook your computer up to the router and change the ip address to 192.168.9.1. On your router change the router mode to static ip address mode. Then you will need to know your username and password from you cable company, and the Domain Number. Then connect the cable back to the wan port from the modem and the other end to the wan port of the router. Connect the computer to the first lan port on the router and type 192.168.9.1 go to the status page and tell it to connect.
Your cable company is giving you one ip addres and have to pay for another for more than one computer. What are you doing is using the router to receive the first ip address and distrubting out to the other computers.
Nov 24, 2009 | Linksys WRT160N Wireless Router
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
How to setup an adsl modem and a router
forget the router as it appears that it is messing with the connection
May 13, 2017 | Cnet CNIG914B 4-Port 10/100Mbps Router
Cnet broadband cnig-914
Nov 09, 2006 | D-Link DI-704P Router
Computers & Internet Logo
78 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
